by KCStudly » Tue Jun 19, 2012 2:51 pm
Thanks, LarryC. The epoxy probably would have been a good choice, too. I was attracted to the 30NF because it is water cleanup, one part, and has a 30 minute working time to get things right (IIRC). Not that you can move things around for 30 minutes, but that the window of opportunity to get the two surfaces together is about 30 minutes after the tack time.
Aggie79, did you get a different result from Linuxman? Over on my build thread, where I asked more or less the same question as OP, he has indicated that he has seen no problem with applying TB3 directly over the sprayed on adhesive. Best I can tell he has the most experience here with the 30NF (not sure how long his first build has been in test mode, though). You mind me asking what leads you to believe it would be bad? That was my initial thought, too. It seems like it could go horribly wrong in the "chemical soup", so I am looking for valid input, real world experience from both schools of thought. It’s kind of hard to argue with firsthand experience, though, and from what I can tell he has used the same method for at least a few builds.
As of right now my plan is to:
1. Finish adding the centerline blocking.
2. Use TB2, a few brads or staples for alignment, glue the bottom skins on, and weigh it down with heavy stuff to cure.
3. Trim the excess ply from the edges.
4. Flip it right side up.
5. Pre-fit foam.
6. Template the mounting hole locations from the trailer frame.
7. Drill and install the blind thread inserts (counter sinking slightly as required).
8. Spray the adhesive being careful to concentrate on the inside face of the bottom ply (avoiding the frame top and insides as much as possible without going to the trouble of masking).
9. Apply TB2 to the tops of the floor frame.
10. Use leftover slats as "stickers" to assist in placing the top floor skins, running a screw in here or there to keep the skins from shifting while I pull the stickers out.
11. A few brads or staples and weight to cure.
12. Trim excess top skin.
Thanks everyone for the input. I'd still like to hear more on the subject if it's out there.
My Build:
The Poet Creek Express Hybrid Foamie
TnTTT ORIGINAL 200A LANTERN CLUB = "The 200A Gang"Green Lantern Corpsmen
