First some background on me and what I wanted out of a new conversion.
I've owned two previous travel trailers: A pristine 1954 canned ham Aljoa and more recently, a 4x10 teardrop for the past 5 years. My camping and trailering needs have evolved in that time: In a nut shell, I need more room than I have in my nutshell of a teardrop.
I have a need to haul a lot of play things: paddle boards, mountain bikes, motorcycles. I also build and haul "one off" custom pedal / electric tricycles. These trikes can get big. My current trike is 4 feet wide, 9 feet long and weighs 380 lbs. A photo of it "attached" to my teardrop follows.
I do a lot of "shoulder season" camping (fall and spring). The weather varies from windy and in the low 100's to snowing and in the 20's. (As "tear-jerkers" know, sitting down to a morning cup of coffee when it's snowing can be a challenge.)
My haul vehicle is a 2007 Lexus RX 400h.
So I wanted a toy hauler/travel trailer that had the simplicity of an "egg" or teardrop, and weighed less than 3500 lbs loaded. But, it had to be big enough to carry toys, camping gear, 2-3 BIG dogs, the wife occasionally, and me comfortably, (I'm 6'2").
Commercially there is nothing out there that fits that bill. So I'm building my own. My budget? Well, a new "egg" can run more than $ 11,000. I figure this will be nicer and cost less. I'm calling it the "SQUARESTREAM".
I ordered the trailer in January from trailershowroom.com, and picked up in April from Oregon
Specs:
+ 12 foot x 7 foot
+ V nose
+ 2 RV Horizontal slider Windows
+ RV side door
+ 5.2 K pounds Torsion, Single axle
+ Narrow track axle
+ 30 amp breaker box
+ 2 baggage doors
+ 12 v fantastic fan
+ 10 foot awning
+ 7 foot ceiling
+ Bright plate exterior plating
I am taking many interior design elements from AIRSTREAM trailers : polished aluminum ceiling highlights and cabinet edgings, recessed LED lighting, overhead cabinets.
From the teardrop / egg world, I am taking the lightweight route; Solar shower, port a potty, Ice box, Clean and Grey water in portable 5 gallon tanks, all 12 volt LED lighting, Solar panel to charge sealed lead-acid 12v battery, small catalytic heater.
From this forum I will appropriate: a small "window" air conditioner mounted as needed in a dedicated small cargo door, foam insulation, vinyl flooring and other inspiration.
12 volt rough wiring and 1 inch wall and 1 1/2 inch ceiling insulation is in.
I placed the heaviest elements ( microwave, ice box, sink, dresser) as close to the axle as possible. The spare tire, water, generator, and battery will be placed at the rear of the trailer under the bed. This will help keep the tongue weight reasonable.
The bed will be across the rear of the trailer. It will spit down the middle, with the ends hinged to the walls . That way it can be folded up to increase storage space and permit access through the rear cargo doors. (kind of like a Murphy bed, split down the middle)
THe Kitchen will be on the street side, a dresser on the curb side and a couch will go across the front.
In this photo you can see the aircraft aluminum that makes up part of the ceiling. (Is is partially obscured by a protective film of white plastic.) I bought 3 sheets of 4x10, 0.032 polished aluminum sheeting from an aircraft supply house. This BRIGHT (Yikes!) aluminum will be also used as backsplash, molding, highlights, and trim throughout the trailer.
Today I started laying down vinyl "oak flooring".
After that comes the cabinets, kitchen counter, dresser, and couch. The big cabinet that holds the microwave, Icebox and pantry is already done, but not placed. I hope to be operational by July 4th and fully finished by Labor Day.
