Goatdog wrote:Good job. I like the security my peepholes give me.
I only have a smoke detector. I haven't found a Carbon Monoxide detector as cheap as you did, so off to Home Depot I will go. I am also looking for a LP alarm...did you see one there?
bigbendhiker wrote:Don,
I ordered (and have received) several of the same brand 12vdc receptacles that you are using. They seem to be really high quality units. I plan on using them in my conversion. Glad to hear they are working well. I'll have to look into that 12v fry pan.![]()
I too like the idea of the smaller propane tank. I doesn't make sense to carry a full size tank around unless you have a need for that much propane. Great deal on the propane.
Question for you; what size/brand of battery are you using? I've looked online at some, but I'm still looking.
Thanks,[/color]
d30gaijin wrote:
Scott,
Guess I am using a little more than a standard auto battery. I bought it back in 2010 and forgot what the heck I had even bought. Be that as it may, it is an Interstate Battery Deep Cycle Marine. Pic of battery is below. You can see the two thumb screw connections I was referring to. For a CT it is much handier using those connections than having to install full size automotive connections and the huge cables they require, neither of which, are necessary to power a CT interior.
Don
8ball_99 wrote:Nice I'm sure it will come in handy. I'm not sure I'd try to run that one on a 5 gallon tank though. I'm sure you know but its only rated at 15% duty cycle. In a pinch it would probably be ok. But You would probably burn it up pretty quick with much use. The thermal protection doesn't really help all that much. I've known a few people who have burnt them up. Infact I would love to add a second 480c to my truck just cause I use it more then I ever thought I would. I have a feeling mine is running a little more then it probably should.
If I were you I would go ahead and mount it to your tow vehicle. That way you always have it with you camping or not. They are pretty handy.. I used mine for tools for work all the way down to blowing up balloons at a birthday party lol.
OH btw I got my co and gas detector from Lowes. It detects flammable gas and is also a CO detector. It plugs into 110v but also has a battery back up.. I hardwired the battery back up part to the onboard battery. So if the trailer is plugged in it runs off 110v if not it just pulls from the main battery.
cam_tx wrote:Just looking through all the posts and again. Many great ideas of yours that I will try and incorporate. Just wandering if you had any pictures with your cargo all loaded for camping with the Sportster loaded as well. I wanted to see how you have your bed/mattress mounted when you travel with the bike.
My cargo will be hauling my Ultra Classic or side-by-side, depending on where I am headed. I have a bike trip planned for this summer up to Montana but the trailer will be staying home on that trip.
Did you do more work on your upper cabinet?
That will be my main cabinet because I will need to get to the e-track across the front of the CT for tying down the bike or side-by-side.
d30gaijin wrote:Surprise surprise, a wonderful surprise arrived today. The custom built overhead galley doors I ordered back on the 18th of June arrived today. I didn't think they'd be here before we were scheduled to leave but low and behold they arrived today. I ordered them from "Fast Cabinet Doors" in California. All their doors are custom built to the users specifications, in my case I needed red oak raised panel doors measuring 10" x 22" and figured they would take a month, or more, to get here. Not so. The price was $38 for the pair (very reasonable but the shipping was the killer, but then again, the way they package them I can understand the $27 shipping cost). They match the red oak plywood cabinet face very well. I'd post a pic but am having problems uploading pics to the tnttt.com server for some reason, I keep getting an "internal server error" message. Will update this post with pics once I can upload pics to my album.
Timing wise it couldn't have worked out better. I finally cut the overhead galley cabinet face a couple of weeks ago, something I kept putting off due to my limited wood working skill. Still, once I got the cabinet faces cut to fit the CT roof contour I was reluctant to cut the door openings so kept putting that off too, well until yesterday. Yesterday I decided I had to make the door opening cuts no matter what, and did so because we will need access to that upper galley space for storing things whether the cabinet doors arrived or not. Well Hallelujah! The cabinet doors arrived today.![]()
Don
