norcal2 wrote:do you have pics of the front wiring? is it a v nose? i notice they do the v nose different on different models....
Bkcreation34 wrote:I bought the trailer and been buying things for it over the past couple of months. I started first with taking the factory paneling down and notice what others have run into and that is the factory wiring is horrible. For haulmark brand I was hoping for a better job on wiring. So to be safe and for it to last I am in the process of having it all rerun for wires. The factory job was loose connections and wires run in front of metal stud and covered by panel, who does that because overtime wire will rub and short out from exposed to metal stud. I have a deadline due to going to AL on the 31st. I have a large project list and friends to help me get half way there. My main focus is to fix the factory wiring and then wire in 120 volt service. I am going overboard on the panel but I rather go big then to small, I am going to have 2 gfi waterproof outlets outside of trailer. Then gfi inside and then 10 outlets around the inside. I bought a 30 amp service cord and outlet for camper to use at campground. I will have pictures soon. Also one other thing with factory job at haulmark up by v-nose when I took the paneling off I saw a large gap I could see straight outside what the heck. And it was missing one steel support by v-nose so a lot of unexpected things needed to be fixed before hand. Does anyone have any good spots for camping in Kentucky and tenn and AL let me know.
For 12 volt service I bought a samlex 50 watt solar panel for roof with a tilt mount to charge battery so when I go off grid I can have ights yet.
Users browsing this forum: Google [Bot] and 3 guests
