Cleaning Alum Window frames
Canned Hams of all types and sizes...and Bread Boxes to go with that ham......
Postby Wishbone » Sun Jun 24, 2012 7:23 pm
I'm going to take out my windows one by one & reseal them. I was wondering whats the Easiest way to clean crud & polish them up a little. Wishbone-Ks
Wishbone
Re: Cleaning Alum Window frames
Postby emiller » Tue Jun 26, 2012 9:24 pm
Do you have a picture of your windows. I cleaned mine with just some aluminum polish by hand.
emiller
Images: 157
Postby bohemian » Sun Jul 01, 2012 8:35 pm
S.O.S works for me. :thumbsup:
bohemian
Images: 233
Postby 48Rob » Mon Jul 02, 2012 6:19 pm
You can try chemical cleaners, if the crud is "light" they might help.
Usually, grit is needed to remove the dirt, and oxidized layer(s).
What type/size of grit you need to use depends on how nice you want the metal to look.
Larger/coarser grit will give you a rough and somewhat shiny look, finer grit will give it a more polished, mirror like finish.
A wire wheel on a grinder will "clean" the metal, but give it a rough look, while using metal polish with a cloth wheel will also clean the metal, but leave it much smoother.
All personal choice.
Rob
PS. a sandblaster will work well, and fast, but it won't be shiny... ;)
48Rob
Return to Canned Hams & Bread Loaves
