angib wrote:In my opinion, everything except the tongue/A-frame and the suspension cross-member (because you're in the UK, I assume you'll be using half axles), is just:
a) decoration;
b) something to hold up the floor until the walls are fitted;
c) reassurance for those who think they are building a small house.
Add,
d) rock rails to keep the wood bits from turning to splinters when dragged through the rough and tumble of the great outdoors.
I do appreciate the notion that most over the road campers are probably overbuilt a tad, but sometimes there is a good reason to over build. There are exceptions to every rule; for example, traveling off road, or on rough back country roads.
Rocks, washed out gullies, and especially dropping onto a ledge would do a quick number on an unprotected ultra light box
I have visions of thin plywood gouged open and spilling foam guts all over the trail, or a heavy galley sagging down, wall skins bulging after dropping hard onto a rock ledge right aft of the bulkhead. Oh sure, it would take a hard hit to do any real damage, and if built right you might just poke a small hole and have some scratches under the rear “bumper”, but when I'm hundreds of miles from the next human being, I need the confidence that steel provides, and I don’t want my dream trip to be soured by preventable damage.
Steel can be dragged over a lot of rocks before it starts having serious issues.
Label me a fat American with a gas guzzling SUV (two, actually). I’m not offended in the least.
It’s true.
I could build lighter, but there are no plans to attach wings, so…
To everything there is a purpose. When building light make sure you understand the purpose of each thing so you can make it just strong enough. When you are not sure what you will encounter, you have to make some allowances. That's all, really.
Peace.
