grandkinstudios wrote:Thank you!
I want both 110v (30a) and 12v, and I have seen quite a few pictures other have posted regarding their electrical systems. It's slowly sinking in and making a bit more sense. Loading missiles on military aircraft is so much easier!
Questions:
The difficult part I am having is understanding the main components I will need to purchase in order to accommodate my TD. Here is what I do know, taken from the Benroy plans:
- 110v inlet + 12 gauge wire (I assume Romex?)
- Electrical boxes + outlets for 110v + 1 GFI
- 12v converter
- 12 v plugs (cigarette type)?
- 12 v fuse box
- 16-2 sound cable
And I want an inline 30a surge protector wired into the system.
What I am trying to wrap my head around is how to wire the first few components, i.e., in which order should I follow?
For example: (would this be a good starting point, and once I have accomplished this then stop?) Or am I missing something such as a circuit breaker with 2 x 15a?
110v inlet > 30a surge protector > 12 v converter > 12v fuse box?
pmowers wrote:Welcome! You probably want to put insome circuit breakers as well. A convienent way that many have combined tge converter,12V fuse box, and breakers is through the use of either a WFCO or Progressive converter. There are lots of them on ebay and trailer surplus places. You will want to catch surges between the trailer and the source. There is enough info and opinions on the electrial forum to make your head spin.
grandkinstudios wrote:What is the model number for the PD converter?
