The reason for the module is to correct the difference between American lighting and International lighting systems. American cars use the brake light filament as the turn signal, while foreign cars use separate bulbs for the turn signalsdano wrote:On my quest to put a hitch on my Corolla this is what I learned.
Some wiring kits have a module that regulates the electricity. I looked on etrailer and they only sell the one with the module. That means a wire to the battery. I then called the local experts around here and that guy said this.
You need the module because the trailer draws electricity from the battery. The module needs a battery connection.
True or not I don't know. I put a hitch on mine and towed it without lights and didn't like it at all. The trailer hitch will be part of my bike rack and I will tow with my truck. Wish the Corolla worked for me because the gas mileage is way better than on my truck.
My tear is 800 pounds if that matters.![]()
Dano
