Grape Solar 100W PanelCostco
http://www.costco.com/Browse/Product.as ... opnav=&s=1
• 100 Watt, 18.5 Vmpp, 5.42 Impp
• 900mm leads with Male and Female MC4 Connectors
• Panel Dimensions: 47.0” tall x 21.1” wide x 1.57” thick
Solar Power ControllerAmazon
http://www.amazon.com/HQRP-Controller-D ... controller
• HQRP® Solar Charge Controller plus HQRP® UV Chain / UV Radiation Health Tester;
• Equalisationvoltage: 14.8 Volt; High voltage disconnect: 14.4; Float voltage: 13.6Volt;
• Low voltage disconnect: 11.1 Volt; Low voltage reconnect: 12.6 Volt; Self-consumption: 6mA maximum;
InverterCostco
PowerBright 1500 Watt 12 Volt
• Modified Sine Wave
• Continued Power 1500W
• Peak Load Power Rate < 3000W
• Overload Output Power 1560-1400W
• No Load Current Draw < 0.4A
• Input DC Voltage Range 10-15.5V
• Output Voltage Range 117 +/- 10%
• Output Frequency Range 60 +/- 3Hz
• Max Power Efficiency > 90%
• High Voltage Cut Off Level 15.5 +/- 1V
• Low Voltage Alarm Level 11+/- 0.5V
• Low Voltage Cut Off Level 10 +/- 0.5V
• Short Protect Yes
• Overload Protect Yes
• ISO 9001 certified and ROHS compliant
• Standard Test Voltage Input DC 12V
Cables and so onBattery Tender Deltran Cigarette Lighter Adapter 081-0069-5 (So I can “back charge” through the 12V connection)
http://www.amazon.com/Battery-Tender-De ... sim_auto_5
Battery Tender 021-0123 Battery Tender Junior 12V Battery Charger
http://www.amazon.com/Battery-Tender-02 ... uto_text_b
Battery Tender 081-0069-6 Ring Terminal Harness with Black Fused 2-Pin Quick Disconnect Plug
http://www.amazon.com/Battery-Tender-08 ... auto_img_c
thanks in advance!
