AGM 2572 Restoration
Postby Lazybones » Fri Jul 13, 2012 6:46 pm
Here is another AGM with a stress cracked fount saved. I bought this thinking it was in working condition, only to find it had a tiny leak in the fount.
It had a perfect vent and the original yellow globe.
Monday I took the vent to the paint dealer and had custom auto paint mixed to the right color then put into rattle cans.
Then took a Sears fount. Drilled and tapped it to take an adapter that would accept the AGM valve. If the fount had the pump on the opposite side you wouldn't be able to tell the difference.
Is it true? Is it necessary? Is it kind? Ask yourself these simple questions every time you are in doubt about any action.
Lazybones
Images: 49
Re: AGM 2572 Restoration
Postby campmaster-k » Fri Jul 13, 2012 10:54 pm
Another save by Lee. Keep up the good work. 8)
-Kirk
>CEO Coleman Recovery Inc.
Build thread -
Check out my Pictures -
campmaster-k
Postby doug hodder » Sat Jul 14, 2012 1:15 am
Good job Lee....I love creative solutions to bad situations.....that's what makes a craftsman....Doug
Postby Woodbutcher » Sat Jul 14, 2012 8:07 am
Beautiful job! It looks great. :applause:
Woodbutcher
Postby Joamon » Sat Jul 14, 2012 3:39 pm
Lee looks great :thumbsup: Can you explain and or show what kind of adapter you used. Would like to try it myself.
Thanks Keith
Joamon
Images: 244
Postby Lazybones » Sat Jul 14, 2012 3:57 pm
Joamon wrote:Lee looks great :thumbsup: Can you explain and or show what kind of adapter you used. Would like to try it myself.
Thanks Keith
Keith,
Sorry ;I didn't take in progress pictures. But; It's pretty straight forward once you get into it.
The first thing you need to do is measure the height your valve stick out on the original AGM fount. You need to make sure it's the same including the adaptor when mounted on the new one. I had to grind off most of the original coleman threaded nipple to get this measurement right.
Then I just bought a 3/8" to 1/8" pipe adaptor at the auto parts store then drilled the fount out to the correct tap size.
If you have any more questions feel free to ask.
Good luck!
Lee
Lazybones
Images: 49
Postby jeff0520 » Sat Jul 14, 2012 5:48 pm
OOOH...It's a lantern! The only place I've ever seen the designation "AGM" used was "Air to Ground Missile." I thought somebody was going to EXTREMES to discourage bears from tearing up the camp. :lol: :lol: :lol:
Hypno-Toad's Command Post, the build thread! http://www.tnttt.com/viewtopic.php?f=50&t=50384
jeff0520
Images: 128
