Trimming ends of hurricane hinge (?)
Postby les45 » Thu Jul 26, 2012 7:07 am
Anyone have a detail on how they trimmed out the end of their hurricane hinge? I installed mine with about 3/8" overhang on each side (that's just the way it came; no cutting) and left both pieces of the hinge at the same length. I see where some folks cut off the rear piece flush with the body. My thoughts are to leave both pieces long and simply round off all the sharp edges. I will be installing the L-shaped edge trim with vinyl insert on both sides of the hinge. (PS - that gap under the hatch gets a D-shaped rubber seal after painting.)
les45
Images: 605
Re: Trimming ends of hurricane hinge (?)
Postby ssrjim » Thu Jul 26, 2012 9:34 am
If it were mine I would trim the hatch piece flush but not trim the none moving top piece. I'd likely add the slightest of a grove 1/32 inch to the underside to break the surface tension of the water rolling down the groove so it will drip off rather than roll down the trailer side.
93079
ssrjim
Users browsing this forum: Google [Bot] and 9 guests
