The Micro Pod is designed to be a 2-person TD/Tent hybrid that is actually built on the HF 48x40 frame.
angib wrote:This is a neat design idea and if trailer length was a particular concern (like on some ferry crossings, or maybe just for storing in a garage) then it would be great. But apart from that, I don't think it's a big benefit to make the trailer so small and I would give three reasons:
- it will certainly be a lot more work to make the trailer with a fold-out section;
-- the cross section is the same as a regular teardrop, so it won't have any less drag when being towed;
making the fold-out is likely to be as heavy as a fixed trailer.
The weight issue isn't obvious but I think, although a 'canvas' and tube frame sounds light, there is a lot of stuff needed to make the folding floor strong enough and to hold it in position, so the weight saving would get lost by the time everything was included.
TJinPgh wrote:The raised platform is 1 foot high. The floor of the cabin needs to be raised up a little to get above the fenders, unless you want wheel wells in your sleeping area.
Obviously, you could simply use 2x2 and bring it up a couple of inches and be above the fenders but I figured that doing so is ultimately just wasted space. By bringing it up a bit you create usable storage space.
So, the answer to your question is 5' plus however high your frame is.
The overhang is only 10" in each side so I don't think there should be a huge stability issue. The whole unit ends up being about as high as it is long and wide.
