windows
windows
Postby bobnlyd » Fri Jul 27, 2012 6:58 pm
what has everyone done for windows...is there a good outlet or dealer..i am finishing the last bit of details on my trailer and am stuck on ideas
bobnlyd
Re: windows
Postby CliffinGA » Fri Jul 27, 2012 10:57 pm
I bought mine off of ebay but when I fo my next I will probably either get a set from Grant at:
http://www.lilbear.teardrops.net/parts4.html#windows
the 18"x 15" from this company http://www.teardroptrailers.net/category_s/38.htm
Cliff :thumbsup:
My Build:
viewtopic.php?f=50&t=42628
CliffinGA
Images: 207
Re: windows
Postby JJKC » Sun Jul 29, 2012 5:01 pm
I used EZ breeze windows in my last build and they worked great. Their on a 4 track system with glass part being vnyl so there pretty tough. You open them up or down and have 2/3rd's of the window open. You can even get them tinted if you want.
JJKC
JJKC
Images: 15
Re: windows
Postby Lgboro » Sun Jul 29, 2012 6:46 pm
I used windows salvaged from an RV. Junkyards and larger RV dealers that do repair work will usually have them.
Lgboro
Images: 53
Re: windows
Postby WillemII » Mon Jul 30, 2012 1:03 am
Hi
Does anyone know of windows suitable for walls of less than 1" thickness? I don't really like the option of using spacers, as I would like the inside as flush as possible.
Willem
WillemII
Re: windows
Postby DudKC » Tue Jul 31, 2012 10:04 am
WillemII wrote:Hi
Willem
I got my windows from the eBay seller I linked below. You can order a trim ring to fit any size walls from under an inch to 2 1/4". They are good quality and from the few test fits we've done it looks like they will install easily and look nice when we're done. They come with a pretty decent looking weather seal, so when you attach them to the trim ring it will seal the outside wall against the weather seal, looks like a pretty painless install.
http://www.ebay.com/itm/RV-Teardrop-Tear-Drop-Trailer-Windows-1-New-21-x-14-/260658774325?pt=Motors_RV_Trailer_Camper_Parts_Accessories&vxp=mtr&hash=item3cb0794135#ht_720wt_1270
Dustin
View my build thread here:
http://www.tnttt.com/viewtopic.php?f=50&t=42426
DudKC
Images: 100
Re: windows
Postby Robbie » Tue Jul 31, 2012 12:23 pm
I used the 15"x18" crankout windows that Grant sells. They are very sturdy and the crank out opening is great for when you want some fresh air and its raining as the water can't get in the opening. They were very easy to install in my .75" thick ply doors.
Here you can see they mount darn near flush on the inside...
And from the outside... The windows have plastic covers for the screws, I just hadn't mounted the left side yet.
My aluminum benroy build:
viewtopic.php?t=45640
Robbie
Images: 86
Re: windows
Postby WillemII » Tue Jul 31, 2012 1:53 pm
Thanks for the suggestions, DudKC and Robby. I particularly like the crank-open window, also very smooth on the inside. Nice window indeed. And a very nice build, Robby! Where would I find details on this Grant?
Willem
WillemII
Re: windows
Postby WillemII » Tue Jul 31, 2012 4:04 pm
Didn't look far enough... link for Grant is above. :thumbsup:
Willem
WillemII
Re: windows
Postby bobnlyd » Tue Jul 31, 2012 11:13 pm
think i will need windows for about 2 3/4" walls..has anyone ever made them
bobnlyd
Re: windows
Postby CliffinGA » Wed Aug 01, 2012 10:59 am
The ones I got off ebay you could get for any depth, you just had to let them know so they would send the correct depth trim ring.
Cliff
My Build:
CliffinGA
Images: 207
Re: windows
Postby bobnlyd » Wed Aug 01, 2012 5:52 pm
cool thanks
bobnlyd
Re: windows
Postby markhusbands » Wed Aug 01, 2012 7:32 pm
I like the ones on Grant's site, but I'd like mill finish ones better. Anyone know where you could get those? I even thought jalousie windows might be nice...
133923
markhusbands
Images: 58
Re: windows
Postby Robbie » Thu Aug 02, 2012 7:34 am
bobnlyd, have you looked into shed windows at all? Some people with the thicker walls use them and they can be found very cheap!
http://www.ebay.com/itm/SHED-WINDOW-PLA ... 61ce40197a
Robbie
Images: 86
