Working with Aluminum
Postby noncompusmentis » Sun Jul 29, 2012 2:39 pm
Help... please!!
I need to 'alter' some aluminum trim. I can't find a substitute, so I need to recycle some old trim (it's from an old caravan door) as it has the right profiles.
Below is a picture of the current trim:
All the 'inner' grips need to be removed. I've mocked up a picture of how I want it to look afterwards:
I tried to cut a bit out with a dremel type machine with tiny cutting discs, but it's awkward and VERY time consuming. I need to do about 3m in length including some pre-formed corners.
The inside width that I need to clear is 18mm.
Any ideas how I can clear the internals out without overheating the metal?
Hopefully the knowledge of TNTTT will have some suggestions!! :)
Cheers
andy
noncompusmentis
Re: Working with Aluminum
Postby mallymal » Sun Jul 29, 2012 2:45 pm
Router with metal cutter & router table, so you could feed it along a fence? Just my 5c worth....
mallymal
Images: 18
Postby 72FJ40 » Mon Jul 30, 2012 1:12 am
First choice: Milling machine. Have a friend with a mill in home shop? A machine shop can do this, but no guess as to cost.
Not sure I would try the router. Speed of cutter and hand feeding the metal sounds like a certain danger.
72FJ40
