Gage wrote:Build it again. This time build it to the tear and fit check it to the tear before you install it. Take your time and check your work as you go. Don't get in a hurry and don't 'short cut'.![]()
"hatch framing completed, now to locate hinge & latch"
"fit check & looking for spring back, looks good, no spring back"
Melven wrote:This is actually the second time I built it. and it fit fine before I put the skin on. I may have to build it again but I would really like to make it work if I can. When I push in on the bottom it does sit flush. Yours looks great by the way
Gage wrote:Melven wrote:This is actually the second time I built it. and it fit fine before I put the skin on. I may have to build it again but I would really like to make it work if I can. When I push in on the bottom it does sit flush. Yours looks great by the way
Are you using 1/4" or 1/8" ply?That may be part of your problem. People just don't understand that 1/8" will work with fewer problems and is plenty strong. If the bottom will push in easy, then you might consider doing what Eddie suggested using 'Draw latches'.
Melven wrote:I used 1/4 inch. These draw latches, do I have to make them or is there some on the market I can check out.
I really appreciate your help by the way.
Ken
emiller wrote:most Ace Hardware or Home Depots/Lowes sell them and they come in different sizes and type.
CliffinGA wrote:Ken did you have the hatch resting on the floor before you skinned it? Mine for some reason while setting on the concrete developed the same thing where its like warped a little on one side. So I plan on getting some also like that but a little different more like the ones on pop ups that are adjustable and you can add a lock to if needed like this:
Cliff
