Hatch help
Hatch help
Postby Melven » Tue Jul 31, 2012 2:56 pm
I installed my hatch yesterday and it sticks out funny on the bottom. I think the skin made the hatch stretch back some. any advise on how to deal with this. I need help.
Thanks guys.
Melven
Re: Hatch help
Postby DudKC » Wed Aug 01, 2012 5:49 pm
I was hoping this thread would get some good replies because I think that was part of our problem with our hatch. I'm not sure how to fix it so we were just going to scrap it and build a new hatch. We used 2 pieces of 3/4" particle board laminated together for the side ribs, I thought that would be plenty strong to hold the bend in the luan we used. Since our hatch is 6 feet long we ran the luan horizontal and bent it against the grain. This time we are thinking of running the luan vertical and having a vertical seam down the middle in the hopes that it will bend easier that way and might not pull the hatch ribs out of shape. Thanks for posting the thread, I'll keep my eye on it for suggestions or any updates from you on how you fixed yours. Or I'll come back with (hopefully) a new and functional hatch.
Dustin
View my build thread here:
http://www.tnttt.com/viewtopic.php?f=50&t=42426
DudKC
Images: 100
Re: Hatch help
Postby emiller » Wed Aug 01, 2012 6:10 pm
I had spring back on my first hatch and now build all my hatches out of 1" steel tubing.
emiller
Images: 157
Re: Hatch help
Postby Melven » Wed Aug 01, 2012 7:17 pm
DudKC wrote:I was hoping this thread would get some good replies because I think that was part of our problem with our hatch. I'm not sure how to fix it so we were just going to scrap it and build a new hatch. We used 2 pieces of 3/4" particle board laminated together for the side ribs, I thought that would be plenty strong to hold the bend in the luan we used. Since our hatch is 6 feet long we ran the luan horizontal and bent it against the grain. This time we are thinking of running the luan vertical and having a vertical seam down the middle in the hopes that it will bend easier that way and might not pull the hatch ribs out of shape. Thanks for posting the thread, I'll keep my eye on it for suggestions or any updates from you on how you fixed yours. Or I'll come back with (hopefully) a new and functional hatch.
I was thinking lag bolts through the structure to pull the bow out.
Melven
Re: Hatch help
Postby CarlLaFong » Wed Aug 01, 2012 8:18 pm
Can you make some relief cuts in the ribs and pull it back into the proper curve? You could then sister up some new ribs along side of the existing ones to hold it in shape
http://jkcallin.blogspot.com/
CarlLaFong
Images: 5
Re: Hatch help
Postby Gage » Wed Aug 01, 2012 10:09 pm
DudKC wrote:I was hoping this thread would get some good replies because I think that was part of our problem with our hatch. I'll keep my eye on it for suggestions or any updates from you on how you fixed yours. Or I'll come back with (hopefully) a new and functional hatch.
This same question was addressed in the 'GENERAL' section with qualified answers. This thread needs to be locked up so as not to cause any confusion. :thinking:
Image Image Image
Gage
Images: 28
Re: Hatch help
Postby Melven » Thu Aug 02, 2012 5:35 pm
I posted it in two places so I would get some replies.
Melven
Re: Hatch help
Postby len19070 » Thu Aug 02, 2012 7:06 pm
I solved the "Spring back" problem by using materials that don't Spring Back!
Kind of a "Homer Simpson" approach. Doah!
FRP and Aluminum...don't spring back!
Happy Trails
Len
len19070
Images: 24
Re: Hatch help
Postby DudKC » Sat Aug 04, 2012 7:06 pm
CarlLaFong wrote:Can you make some relief cuts in the ribs and pull it back into the proper curve? You could then sister up some new ribs along side of the existing ones to hold it in shape
We tried this today. The last post in my build thread has some pictures.
I'll come back tomorrow or the next day with an update on whether or not it held up.
Dustin
DudKC
Images: 100
