Becky its easy to bend mostly on the curves but so far finding a way to keep it fastened has been fun. Grant said to use carpet nails and so far neither of the box stores has any of them. Screws poke out to much and brad nails eventually pull out. I picked up some brass screw nails and will try those sometime this week. I did find out that between the t-molding and the edge/jamb molding you have to have atleast a 1/4" for the t weather stripping I got from Frank. Ths means you have to have atleast 1/2" gap between your door and wall in the opening, whic h has left me doing alot of shaping on the door with a sander
. Sometimes just to fix some of my earlier fixing! The hatch has come away with the skin glued good but I need to add extra support so I can reglue the seam.
I will try and get that this week as I will be home every night this week and should be able to get some more done on the tear. Just as a side note, this is a cooler a friend gave me and after I paint it this may be its final home:
Its a 6/77 coleman steel belted cooler that will become a battery/stabizers box on the tongue.
Wells thats the update this week as not much was done due to working out of town and raining here most of the weekend and I was just exhausted from last week.
Cliff
