FL 5x9.5 Side walls mocked up 8/18/12 pg.2
Re: my first teardrop in FL. 5 wide
Postby GRY GHST » Sat Aug 04, 2012 11:57 pm
picked up the wiring harness for the V50 tonight along with some LED marker lights for the trailer.
can't wait to make some more saw dust tomorrow (possibly getting the profile on wood)
I'd like to be camping by September
John
my 5x9.5 build viewtopic.php?f=50&t=51618
GRY GHST
Profile cut out started
Postby GRY GHST » Sun Aug 05, 2012 11:44 am
well I got the deck mocked into place this morning. screwed the four corners
then I spent more time on the profile taking cues from the ATMA travelear.
got one side profile cut out.
and got the plywood stretched to finish the profile
hoping to get the second profile done tomorrow after work.
John
GRY GHST
Re: my first teardrop, 5 wide in FL. 5 wide
Postby Robbie » Mon Aug 06, 2012 7:54 am
Your build is looking good and moving along quite fast! Have you given any thought to extending the tongue of the HF trailer? Much like Zach and many others have done. It gives you a bit more stable tow then without it.
My aluminum benroy build:
viewtopic.php?t=45640
Robbie
Images: 86
Postby jbyrd » Mon Aug 06, 2012 8:43 am
looking really good so far. to answer your question about the window being mounter vertically, mine are done that way, (cargo doors) I used some stick on foam window gasket replace the factory stuff looks like its holding up just fine so far. If i see a problem i will probably grab some rv door and window gutter to use above it.
Til later, See ya
Jeremy
My build journal #1 "SOLD" : viewtopic.php?t=45945
my build journal #2 "SOLD": viewtopic.php?f=50&t=59216
jbyrd
Images: 172
Postby GRY GHST » Mon Aug 06, 2012 3:12 pm
Thanks guys
Robbie wrote:Your build is looking good and moving along quite fast! Have you given any thought to extending the tongue of the HF trailer? Much like Zach and many others have done. It gives you a bit more stable tow then without it.
yes I am considering the tongue extension, also debating on whether to flip the axle or not.
John
GRY GHST
Postby GRY GHST » Tue Aug 07, 2012 5:00 pm
After work today, I stopped by the local metal supplier to get a price on aluminum skin.
It will be about $400 for the material w/ tread bright for the front end.
Still not sure how I want to finish it off.
Once I got done with that, I came home and cut and stretched the second side profile
John
GRY GHST
Postby DMcCam » Tue Aug 07, 2012 7:14 pm
Hi John, looking good sir! You're really moving along thank you for showing us your progress.
All the best,
Dave
DMcCam
Postby GRY GHST » Tue Aug 07, 2012 7:57 pm
DMcCam wrote:Hi John, looking good sir! You're really moving along thank you for showing us your progress.
All the best,
Dave
Thanks Dave, I've gotten so many great ideas and tips from this site.
I have a pretty ambitious build schedule with the hopes of camping by Sept.
John
GRY GHST
Postby cheri832 » Thu Aug 16, 2012 5:13 am
John,
Your progress is amazing. Are you going single wall? What are your ideas for the interior?
Cheri
Cheri
cheri832
Images: 15
Postby GRY GHST » Sat Aug 18, 2012 1:08 pm
cheri832 wrote:John,
Cheri
I've not done anything in a over a week now I had a house guess last week.
Yes it will be single wall the interior will be pretty simple w/air con. and galley area in back
hoping to get back on it soon
John
GRY GHST
Postby GRY GHST » Sat Aug 18, 2012 4:52 pm
got the side walls mocked up this afternoon
over all height so far just under 65" I think I might flip the axle and cut some height out of the roof to drop it down closer to the height of the V50 57.2 in.
John
GRY GHST
Re: FL 5x9 Side walls mocked up 8/18/12 pg.2
Postby GRY GHST » Sat Aug 18, 2012 8:06 pm
going to borrow my friends belt sander tomorrow to even out the side walls.
also hoping to get the galley cabinets etc. mocked up.
once I have everything mocked up I can take it all apart and water seal everything to prep for final assembly.
still hoping to camp in September, but it will obviously be more toward the end now if not October.
John
GRY GHST
Re: FL 5x9.5 Side walls mocked up 8/18/12 pg.2
Postby Rlowell » Sun Aug 19, 2012 7:21 pm
Nice job so far John. Thanks for sharing your build with everyone.
Hopefully we will meet up some time in the near future as I am just over in Orlando.
Will be happy to offer any assistance.
Rod :applause: :applause:
Plan your work...work your plan...at least that's the plan. Oh, just do it anyway!
gallery/image_page.php?album_id=1425&image_id=76342
Rlowell
Images: 42
Postby GRY GHST » Sun Aug 19, 2012 8:23 pm
thanks Rod
John
GRY GHST
Users browsing this forum: azgreg and 6 guests
