Sixtoedkatz our hybrid build
Re: Sixtoedkatz our hybrid build
Postby sixtoedkatz » Fri Aug 10, 2012 11:55 am
That would be cool for cabinets. :thumbsup: Here's the progression. I tested the poly and poly/stain on the test floor first. I needed to see how to layer it for best effect. They way I thought it would work didn't.96693 So I did 2 layers of the water based poly I had from redoing my stairs 96694 then did a coat of poly/stain I had that the kids like the color of. Only got one coat on. Need to run to HD to get another can of it. 9669596696 Looks pretty good though. No all my wrinkles worked out and everything repuckered when I put down the poly so it will lay flatter when it dries hopefully :worship:
Hope all the pics aren't boring anyone.
Sixtoedkatz
GO OUTSIDE AND PLAY!!
sixtoedkatz
Images: 59
Postby sixtoedkatz » Fri Aug 10, 2012 1:11 pm
96697 2nd coat of the poly and stain. I am using polyshades by Minwax?? They don't carry my color anymore that I started with. (That can was very old.) So we went with what they call pecan. It's alittle redder and darker but got the seal of approval from the girls.
Sixtoedkatz
sixtoedkatz
Images: 59
Postby eaglesdare » Fri Aug 10, 2012 1:46 pm
that looks really good, and shinney (sp?) :wine:
Louella
May the foam be with you.
eaglesdare
Postby TJinPgh » Fri Aug 10, 2012 6:43 pm
the masking tape alfeady. has adhesive on it so it didn't pucker. I wonder if you used glue stick to put the paper down then poly over it if it would work.
-TJ
TJinPgh
Images: 90
Postby GPW » Fri Aug 10, 2012 7:21 pm
We always dampen the paper and use a T2 like glue ... poly over that ... covered many a smooth foam wing with kraft paper and Elmers ... applied damp and smoothed out initially , the paper shrinks to a tight finish ... Can’t do that with just poly ... :thinking:
Postby pete42 » Thu Aug 16, 2012 10:02 pm
eaglesdare wrote:that looks really good, and shinney (sp?) :wine:
yea I'm not the only one who can't speal......speel.........spell
My thought on that is if you get your meaning across it doesn't matter how it's spelted. :)
pete
pete42
Postby GPW » Fri Aug 17, 2012 5:52 am
Doesn’t Everybody have Spell Check ??? Every time I misspell a word (often) I get a red line under it ... and a simple right click on the word produces the correct spelling ... After all , Nobody’s Perfekt!!! :lol:
Postby bonnie » Fri Aug 17, 2012 6:12 am
pete
Pete you made me laugh out loud. Happy Friday!
Remember, the turtle won. :)
bonnie
Images: 107
Postby eaglesdare » Fri Aug 17, 2012 6:24 am
the sad part is that this stuff was my job. i was office personel management supervisor! typing was my fortay (thats probably not the way to spell that one either LOL). now i can't even use my caps where they should go. once i retired, i got lazy with the keyboard.
oh well, like bonnie said: have a happy friday everyone! :wine:
Louella
eaglesdare
Postby linuxmanxxx » Fri Aug 17, 2012 7:36 am
Louella retired????? Aren't you just like around the 40 so that isn't retired just stopped lol :lol:
linuxmanxxx
Images: 10
Postby eaglesdare » Fri Aug 17, 2012 8:17 am
linuxmanxxx wrote:Louella retired????? Aren't you just like around the 40 so that isn't retired just stopped lol :lol:
:lol: i will take that as a complement!
hubby and i are both retired military. he continued working as a civilian, i took on temp work here and there, but "stopped" after i had my son who was a preemie. that was 13 yrs ago. :D :wine:
Louella
eaglesdare
