front design
front design
Postby Ron Dickey » Mon Apr 09, 2012 10:36 pm
almost all teardrops have front as a curve top to bottom. The Raindrop by camp inn goes left to right.
is there any one who has pulled both and could tell any difference.
I know with my present trailer the lower part is flat and I could feel a kinda (what I call Uhaul trail tug) to it until I added the boot in the front curved top to bottom.
I am looking at making a left to right curve in the front and before I commit to a build I must research those areas that are unfamiliar territory.
Ron
173882......173887
Ron Dickey
Images: 787
Re: front design
Postby rowerwet » Tue Sep 04, 2012 7:52 pm
I haven't pulled a raindrop type front, but have pulled the same TD with three different vehicles. With my Ford Ranger I found the flat front starting to really pull above 60 mph, I planned on a tongue box that would match the height of the tailgate and sweep upward to the base of the curve in the front of the trailer. Pulling with my Ford Focus I never really felt the trailer drag unless I got behind a large truck, the disturbed air coming off the truck managed to hit the trailer enough to cause it to be felt, it also pushed it side to side and made me want to change lanes and get ahead of the truck.
Pulling the TD with my Dodge Grand Caravan I didn't feel the drag at all, even behind a large truck. I'm sure the higher back end of the van kept my TD in the "shadow", better than my small sedan. The truck with it's cab 6+ feet ahead of the tailgate didn't give the TD any real wind shadow and most likely had a draft sweeping down over the tailgate as I had a tonneau cover on the bed.
IMO a teardrop or a raindrop will "shed" the air about the same, just look at the number of cargo trailers with V-noses, I think it just comes down to looks, and what kind of TV you have.
rowerwet
Images: 521
Re: front design
Postby Ron Dickey » Tue Sep 04, 2012 10:28 pm
173882......173887
Ron Dickey
Images: 787
Re: front design
Postby Ron Dickey » Tue Sep 04, 2012 10:57 pm
At IRG 4.0 what this trailer
97536
I tried to photograph all the tags on the trailers but missed this one.
The man who owns it said he got really good gas milage.
He like the Raindrop have a boot box as well.
173882......173887
Ron Dickey
Images: 787
Re: front design
Postby Ron Dickey » Tue Sep 04, 2012 11:05 pm
rowerwet wrote:I haven't pulled a raindrop type front, but have pulled the same TD with three different vehicles. With my Ford Ranger I found the flat front starting to really pull above 60 mph, I planned on a tongue box that would match the height of the tailgate and sweep upward to the base of the curve in the front of the trailer. Pulling with my Ford Focus I never really felt the trailer drag unless I got behind a large truck, the disturbed air coming off the truck managed to hit the trailer enough to cause it to be felt, it also pushed it side to side and made me want to change lanes and get ahead of the truck.
You will see a big difference when you add the box but be carful as to what you put in it. To much weight in it when pulling with the little car unless it is a wagon might pull it down, we pull with a carolla and The last time I pulled it out I put the spare tire over the wheel and it scrapped less when going up or down steep driveway ramps.
The van I think it more like drafting. The Australians use a wind and mud block in front of their trailers
173882......173887
Ron Dickey
Images: 787
Re: front design
Postby NateDogg » Fri Sep 07, 2012 8:42 am
Ok this thread definitely caught my attention. I'm now considering left-right for my curve instead of the normal bottom-top curve. I would think it would help with drag also since I'll be towing with a 1/2 ton truck.
NateDogg
Re: front design
Postby alaska teardrop » Fri Sep 07, 2012 2:42 pm
    Hi Ron,
    Ran across this Aerovault Trailer designed by Pete Brock the other day at the races.
    The construction & materials are simular to welded boats. :designing:
    :peace: Fred
alaska teardrop
Re: front design
Postby KCStudly » Fri Sep 07, 2012 4:17 pm
That's pretty cool. Here're a couple more links.
http://www.bre2.net/pdfs/bre2_aerovault_brochure_2011_11_27.pdf?phpMyAdmin=k9QIsjCI-UCmbjFU6X2usBJKjz3
http://blog.roadandtrack.com/tags/aerovault-trailer/
Gulp, just $24k before options. Let's see, how many should I add to my on-line shopping cart? :thinking:
Re: front design
Postby Ron Dickey » Sat Sep 08, 2012 12:35 am
it is true that a lot of it depends on the puller and how it passes the wind on.
a pickup truck vs a car vs a wagon vs taller van.
173882......173887
Ron Dickey
Images: 787
Re: front design
Postby Ron Dickey » Sat Sep 08, 2012 12:53 am
a modern Pickup might do this
and the height of the puller might effect the trailer from wind coming from under the puller.
and a pickup truck youtube offers a s10
http://www.youtube.com/watch?v=rGHnCfJ- ... r_embedded
173882......173887
Ron Dickey
Images: 787
Re: front design
Postby Ron Dickey » Sat Sep 08, 2012 12:57 am
http://www.youtube.com/watch?v=4HLBy-ui ... re=related
Truck and trailer kind of a teardrop. it is really a "Airflow over of my 2008 Mazda Tribute and 2009 Forest River r-pod. The silhouette was created from a picture of my truck/trailer parked on a flat roadway."
173882......173887
Ron Dickey
Images: 787
Re: front design
Postby droid_ca » Sat Sep 08, 2012 3:20 am
Ron Dickey wrote:At IRG 4.0 what this trailer
97536
That's a nice looking trailer...it's got me thinking..wonder what it looks like on the inside
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Re: front design
Postby S. Heisley » Sat Sep 08, 2012 4:19 pm
97536
I, too, was impressed by Ron and Mary Beth’s marvelous teardrop. The flawless canvas front uses the ship-building technique of canvas and paint/lacquer treatment. It is powered by a solar panel and even has a DVD player in the sleeping area. While I did not take pictures of the sleeping area, (didn’t want their cat to jump out), I did get a number of pictures of the outside and galley. Here is what I have of Ron's well thought-out and well done workmanship:
Re: front design
Postby S. Heisley » Sat Sep 08, 2012 4:29 pm
The floor plan of that Aerovault Trailer shows considerable thought and promise. In particular, it shows that, even though the majority of the trailer width is 80", thanks to the curves, the front area is the width of many tow vehicles, and then it graduates out, to get the best benefit of air flow that it can. :thumbsup:
http://www.bre2.net/pdfs/bre2_aerovault ... X2usBJKjz3
Re: front design
Postby droid_ca » Sat Sep 08, 2012 7:34 pm
Thanks Sharon this has me thinking of a fey ideas replace the front with a scratch resistant lexan or plexi glass of some sort and have a window right up front there but for the back end I'm almost thinking PUFFIN so yeah it would be a standy but of a different kind I could make it light and use full length boards...just some food for thought as of right now
“Fide Canem”
droid_ca
Images: 176
