Check your first aid kit
Re: Check your first aid kit
Postby Miriam C. » Mon Sep 03, 2012 5:23 am
:thumbsup: Glad you are recovered and ready to go at it again. For those with cell phones, and purses.....in a pocket where it is available or attached somewhere. My sister, the trucker, slipped on ice at a very lonely stop and her purse went flying. She broke the ankle so she had to crawl to the truck and climb up to get her husband awake. Hours later they got her to a hospital....What went wrong:
Wake someone
Walking stick---I have a cane!
Her cell phone was in the lost purse (they found it the next day in the snow.
A boat horn, the portable kind so it makes noise....3 blasts will usually get help.
Be careful out there! :applause:
Postby JuneBug » Mon Sep 03, 2012 11:03 am
GerryS wrote:.....But a roll of Coban, gauze pads, an a bottle of saline will do wonders to help prevent infection and a SERIOUS problem.
Coban is incredible stuff--this is the stretch stuff that sticks to itself that is used to hold on the little cotton ball when you have a blood sample taken. It is expensive at CVS or Walgreens, so head on over to your feed supply store and check out Vet Wrap on the veterinary aisle. It is the same stuff, but it comes in much wider rolls, in great colors, and is much much cheaper. I do a lot of mountain biking and this is the stuff. In the summer no form of tape will stick to people slathered in suncreen and sweat; you can put a nice stickless pad over the wound/scrape, and hold that in place with a nice bit of Vet Wrap till you can get to a place where it can be really cleaned up.
Coban/Vet WRap will eventually melt to itself after a hot summer, so I unroll a few feet of it, lay it on tissue paper and re-roll it so it isn't touching itself and store in the first-aid kit in the Camel Back that way.
Thanks for the tip on saline solution; I'll be adding that as well.
Don't forget to add in some good carpenter's tweezers in that first aid kit.
PockeTweeze look good as well, if you are into life-time tweezers that can go on your keychain.
"The large print giveth; the small print taketh away" Tom Waits
JuneBug
Postby eamarquardt » Mon Sep 03, 2012 12:59 pm
If it only took 5 hours to get to the ER, have several x-rays taken, get five stitches, and get back to your campsite you weren't in So. Cal. Here that would have taken days (yeah I'm embilishing but just a bit).
Hope you heal just fine.
Cheers,
Gus
eamarquardt
Images: 150
Postby Wild Bill » Wed Sep 05, 2012 6:25 pm
As phones get smaller I have seen them on a leather strap around the neck. Also a couple of things to add to you home built kit. Sanitary Napkins, designed to absorb blood like from a chain saw injury, and large zip tie straps to as a last resort to stop flow from a severed limb. They can also be used to secure an unruly person if need be. Not pleasant things for sure but it helps to be prepared for the worst and hope for the best!! Bill
Beavers are Naughty!
Wild Bill
Images: 63
Users browsing this forum: Bing [Bot] and 11 guests
