Question : keeping double cargo doors open
Postby itschrismck » Thu Sep 06, 2012 9:50 pm
Looking for the best way to keep my cargo doors open in the "fully open" (180) position. Needs to be wind proof, kid proof to work for my needs. I have seen some latches but nothing looks like it will work. I even did the Home Depot walk and nothing. Thanks in advance
itschrismck
Images: 21
Re: Question : keeping double cargo doors open
Postby Hiflyer » Thu Sep 06, 2012 10:16 pm
the barn doors on my trailer came with latches that look like a long T where the head of the T slots into a receiver on the side of my trailer
found pix here
http://www.keithsrvsurplus.com/media/2/ ... e97c_m.JPG
head here for many options:
http://www.horsetraileraccessorystore.c ... olders.htm
They'll open and lock just shy of 270 degrees
Hiflyer
Postby itschrismck » Thu Sep 06, 2012 10:53 pm
Ok those T latches might work. Thank you for the suggestion. Are you not able to rattle the door loose once it's latched? If that's the case they will work. Thanks again
itschrismck
Images: 21
Postby b.bodemer » Fri Sep 07, 2012 11:46 am
My doors use latches like Hiflyer described. When the weather is nice they are always open and latched because the rear wall in my ct is half screen(always providing a nice breeze).
When I picked up my ct from the dealer he cautioned not to keep them latched in high winds. In my case high winds usually mean bad weather and then the rear gets closed up anyway.
No rattle at all on those latches. Feels like a very solid connection.
Barb
b.bodemer
Images: 328
Postby riverfront » Fri Sep 07, 2012 12:13 pm
I took EMT and drilled a hole in one end then opened my door 180 and at the hinge end put a screw then on the oposite door at the outside I put another screw. I then cut the EMT to fit that distance and drilled another hole in the EMT. Once I put the EMT over the screws that went through the EMT I attached a bunggy from one screw to the other. Do the same on the other side criss crossing the EMT. Holds the door open and with a tarp across the top and front plus a piece around the bottom you have a potty/dressing room.
riverfront
Postby itschrismck » Sat Sep 08, 2012 10:59 pm
Thanks gang, I'm going to grab 2 t latches and see how they work will post pix and info. ;)
itschrismck
Images: 21
