jonw wrote:- you use #8 bolts, nuts, and lock washers
CarlLaFong wrote:A better plan is to use spacers or sleeves in addition to the large washers. The sleeves should be slightly shorter than the thickness of the floor. Drill the holes for the bolts through the floor and the frame. Re drill the floor to the diameter of the sleeve, insert the sleeve, the bolt and washer and tighten it down, The floor will crush, slightly, until the washer contacts the sleeve.This way, all the clamping pressure is metal to metal and any further tightening will be unnecessary. If you can find some shoulder bolts, they will accomplish the same thing
CliffinGA wrote:Ask Roly Nelson, I think he built an all wood woody tear!
Cliff
asianflava wrote:This whole "Frameless" thing comes up from time to time. I figure that people do this when they don't want to or unable to weld. Just pay someone to do it!
jonw wrote:...or you can do what I did. The bolts go through the floor and a 2x2 "cleat" that attaches to both the floor and the wall. On top of the cleat is a 1.5x2.5in rectangular metal washer with a regular #8 washer and lock nut on top of it. No floor crushing going on here...
