Saw a Sunrader cabover on E-Bay. It's all fiberglass, has wraparound front windows, seems sturdy ... then I saw the back.
Yep. It's a hatch.
Flat and vertical, but impressive no less:
http://cgi.ebay.com/ebaymotors/SUNRADER ... 2575be5f15
Post a reply
13 posts • Page 1 of 1
No CAD ability; someone help?
Postby Laredo » Tue Jul 20, 2004 11:52 pm
What would it look like with the drawing software to set the Modernistic profile at a 20-degree nose-high angle on the axle, with a steamer-trunk shaped tongue box (that has a false lid covering a solar panel for charging batteries) under the very front?
I have a picture in my head of a 5' wide x 9' long x 52'' high cabin (this would have a 9'' dropped floor running between the wheel wells from end to end to accomodate dinette use; and when the dinette is down it locks into interior wall rails to serve as the deck for a 2nd bunk) and there would be a 6'' wide x 3'' high raised 'railed' skylight -- a detail very similar to the top of the big Jim Dandy design on the one-page leaflet illustration -- centered along the hatch lid, which would only be half as long as usual so that you could have the swing-apart lower half with cabinets built into the doors) and would have fold-down props to brace it open, sitting on a salvage-yard axle assembly (with wheels that include brakes and a matching spare) to allow for integral exterior fenders (wide, deep, fin-shaped fenders pattened after those on the Glen-L.com site boat, L Dorado) that conceal an extra foot of interior width, and the street side one has the 'scoop' at the upper corner that helps hold the spare in place like a '50s pickup) that 'flare' from flush against the bottom of the entry/exit hatches (yes, hatches on both sides; hatches that are oval shaped and interior hinged and swing up gullwing like a DeLorean, but are set at an angle about 15 degrees off straight-up-and-down of their long axes leaning the opposite way from the front edge of the cabin, and each hatch has 'porthole' windows) out to the full 6'' at the fin-ends which are actually flush with the back edge of the closed galley doors. The front wall features aircraft-style triangular windows (all the windows would be Lexan panes in weatherstripped openings with aluminum flashing). In the fins of the fenders would be the stop/turn lights. In the tongue box would be the two batteries. The freshwater reservoirs would be lengths of 4''OD PVC water supply line mounted above the galley countertop in tight S curves to allow gravity-feeding at the laundry-faucet fitting on the deep wet-bar style sink. The stove would be a Harbor Freight gas model with grill and broiler. There would be a coffeepot and a mini microwave on one GFCI outlet in the galley, another GFCI outlet in the cabin, and a rollout slide under the sink for a big cooler. One of the hatches would have an integrated rim for a privacy curtain. Inside the galley would have a large pass through in case of horrible weather (the coffeepot and electric microwave are for such times!) and an overhead fold-down DVD/TV with an FM/WB/CD stereo, and aircraft-style reading lights for the queen size bed and the bunk bed (s) plus a galley light. I would put computer-case ventilation fans in the galley wall and the ceiling vent (and maybe solar power the ceiling vent), and add a bedwarmer. I think I would frame everything with 2''x2'' salvaged from shipping pallets, and use 1/4'' fir ply for the interior skins with clear polyurethane, then a pink foam board insulation layer, another 1/4'' ply wall and, I think, a .040'' metal exterior.
can it be drawn? should it be built?
[/quote]Laredo wrote:and I found that post ...
jeffmutch wrote:Funny, I saw this one on Craigslist for $1000 bucks last week.
M C Toyer wrote:jeffmutch wrote:Funny, I saw this one on Craigslist for $1000 bucks last week.
Jeff -
Even though the seller says no reserve I wonder if he cancalled the previous ad at the last minue because he's looking for more, probably way more, than $1000. Kinda shoots down all my theories about super cheap parts. I guess I'll have to watch how this plays out. It's at $113 now and I'll be kicking myself it it stays in that range.
M X
