more progress
i worked on an off over the weekend and managed to just about finish the rough framing.
My son showed up and we started making every square and plumb.
- 100MEDIA95IMAG09232.jpg (39.39 KiB) Viewed 2850 times
- 100MEDIA95IMAG0924.jpg (43.42 KiB) Viewed 2850 times
- unframed window
- 100MEDIA95IMAG0922.jpg (24.59 KiB) Viewed 2850 times
I am using a batton to approximate the roof line. (yes my shop rafters are too low, will have to move it outside to finish roof).
My plan is to place a 1/2" sheet of 12" x 96" ply on top of the end wall and trace this arch. then i will put two panels together and cut the curve out. Then i will use this as a pattern to cut same curve on three 2 x 12 8 foot long. I will also cut out arch on under side parrell to the top. Once the arcs are made, i will lay out 5 notchs, 16 inch on center for the perlons to sit in to hold up the roof. I will first lay in 4 sheets of 1/8 luan so as to extend over the sides and ends by several inches. Then 30# builders felt, then 29 guage metal 15 feet long to give me a watertight roof.
but that is another story.....
