FRP for the roof
FRP for the roof
Postby docmark » Fri Oct 05, 2012 1:21 pm
Im building a benroy style NO aluminum sides or top. Im interested in using FRP for the roof. Anyone try this? Thoughts? My plan was a thin layer of luan covered by the FRP.
docmark
Re: FRP for the roof
Postby meworrynot » Sun Oct 07, 2012 9:24 am
I'm no expert, but from what I understand, the FRP will not hold up to sunlight. It has no UV protection.
Pete in Texas
meworrynot
Images: 19
Postby LWW » Sun Oct 07, 2012 2:56 pm
How about if you paint it. Then the sun can't get to it.Larry
LWW
LWW
Postby docmark » Sun Oct 07, 2012 5:40 pm
Actually I found FRP exterior panels that are UV rated. I found them thru a big rig truck supply store in widths of 102" and however long you need.. Lowes told me the panels they sell usually sold to restaurants and that the sticker says uv rated also. Plus they can be painted once primered etc.
docmark
Postby len19070 » Sun Oct 07, 2012 11:56 pm
Every time a "Can I use FRP for....." question comes I like to show this example/test.
No Paint, no nothing. Still looks Great.
http://tnttt.com/viewtopic.php?t=35105& ... nother+frp
Yes, it can be used successfully.
Happy Trails
Len
len19070
Images: 24
Postby Shadow Catcher » Mon Oct 08, 2012 4:35 am
Postby bobhenry » Mon Oct 08, 2012 8:10 am
Have 2 builds with the crane plastics Sequencia panels on them and I love it. Going on 2 years and a soap and water bath and they are brand new again.
http://www.tnttt.com/viewtopic.php?f=48&t=30307&start=105
http://www.tnttt.com/viewtopic.php?f=50&t=38489&start=75
Watch out for the dust created by cutting and routering this material I managed to give myself one hell of an eye infection from the dust. Eye protection and a dust mask are a good idea.
Postby Willowagon » Fri Oct 12, 2012 1:15 pm
I covered mine in Home Depot 4x8 FRP, glued straight to the spars & stapled the edges along the top of the sidewall, which are now hidden by the edge trim. The Home Depot FRP strong enough to attach without luan backer, why add extra steps, material & wieght? I insulated between spars w/sheet foam.
I then did a 400g light sanding of the entire traielr and went nuts with about 8 cans of Krylon Fusion UV Clearcoat. The HD FRP, $28 per 4x8 sheet, was about 1/2 the cost of Filon when I priced it. Csot about another 30-40 in krylon clear. I live in So Cal, have had the trailer in the sun all summer and no probs yet.
Willowagon
Images: 16
Postby meworrynot » Wed Oct 31, 2012 5:20 am
[quote="Willowagon"]I covered mine in Home Depot 4x8 FRP, glued straight to the spars & stapled the edges along the top of the sidewall, which are now hidden by the edge trim. The Home Depot FRP strong enough to attach without luan backer, why add extra steps, material & wieght? I insulated between spars w/sheet foam.
What did you use as glue? Think I might use on my camper...
Peter in Texas
meworrynot
Images: 19
Postby docmark » Mon Nov 05, 2012 2:09 pm
Ive always used PL400 adhesive. Its a waterproof subfloor adhesive. VERY strong and lasts.
docmark
Postby Off Grid Rving » Sun Jan 27, 2013 2:41 pm
I had looked into using FRP as well for exterior but the stuff comes to small to do without many seems.
I then found outdoor vinyl for decks.. that stuff lasts a million years, sold locally at lowes and home depot
Check out http://offgridrving.com
--Update--
http://offgridrving.com has been transformed into Community Sites - where you can sign up for your very own project site, chronicle your experiences on the journey at http://offgridrving.com
Get your own space to post updates and pictures and even videos of your build.
Off Grid Rving
Postby BobBash » Sun Jan 27, 2013 8:50 pm
What is this outdoor vinyl for decks ? How is it sold ? Size ? sheets ? rolls ? Pricing ?
Thanks .........
BobBash
Postby Off Grid Rving » Mon Jan 28, 2013 4:52 pm
whats more- they come in all kinds of looks and EVEN have one that looks bubbly identicle to FRP in white or tan and grey
--Update--
Off Grid Rving
Postby meworrynot » Tue Jan 29, 2013 10:35 am
Is it okay to put FRP directly over the framing on the sides, or should I put luan on first? The front, rear, and roof are plywood.
Pete in Texas
meworrynot
Images: 19
