len19070 wrote:In about 1990-91 I built a fence around my Pool.
I wanted it to be a nice privacy fence to sit on the elevated concrete around the Pool.
So I built a painted Cedar fence with FRP for the insert panels.
No paint or anything, just raw FRP openly exposed, both sides to 20 years of North Eastern Winters, Summers, radical Temp changes, rain, sun, Chlorine etc.
And that's a School yard out back, balls hitting it, all the kids, and all things associated with a School Yard.
All the things I'm hearing that FRP is not supposed to do.
I recently had to reinsert a panel that was knocked out of its slot by something from the School Yard. Something that is a regular chore.
The panel was not broken, chipped, brittle or chalky.
In fact it looked as good as the day I put it in some 20 years before.
This is one hell of a test for a material that's not supposed to be able to withstand the Sun, Temp Changes and so on.
I'm convinced that this stuff can be used outside on say....A Trailer Roof that needs a solid nonporous sheet material.
Just my experience with the stuff.
Happy Trails
Len
JIC wrote:To answer GPW question.
Yes and No. Filon is a type of FRP made for rv use, it has a UV protector
added to it.
FRP, from Lowes or HD is intended for interior use only and does not
have the UV protector added.
FRP from Lowes or HD can be UV protection by a good coat of plastic
adhering paint, such as the type they use on plastic car bumpers.
Filon also comes in 102'' width and you can purchase any lenght you
want, it also much more expensive.
I hope this is not as clear as mud and it will help.
Jim C.
steve smoot wrote:I found it Lowes Building Supply, $30 for a 4x8 sheet. They are stocking it in white , tan and gray.
kludge wrote:What are you all doing with the seams?
Paradiseteardrop wrote:kludge wrote:What are you all doing with the seams?
There are trim and corners for the FRP. Same as you use when doing the shower stall. About 2.50 for a 6 foot strip. Its made of the FRP plastic.
There is a 2 foot add on to the side and used it on the back corners.
gallery/search.php?search_id=egosearch
