It's not quite as small as the Pico light that Andrew did, but it's definitely a lot smaller than the giant teardrops and trailers I've been building lately.
If there's an interest, I'll put some more numbers to the drawing...
Strangelymade wrote:Please carry on with this, the prototype looks great already, be exciting to see what you'll be using as the frame and wheels.
angib wrote:It's an interesting idea to push the bed right to the back wall and instead put some storage in front of it - has everyone realized that's what you've done? It would seem logical to me to then make the 'overhead' cabinets inside the cabin open backwards into the galley so that at least has some storage - with the inside storage at the front, the overheads shouldn't be needed so much inside the cabin.
angib wrote:But I can't help thinking that builders would regret that simple back end - easy to build, but I would have thought the under-galley storage was so valuable that it would be worth having a Plan B (not From Outer Space...) with the bed pushed forwards and either a conventional full-height hatch (maybe in only two planes, not three) or a upper hatch and lower doors (which would provide tail light/license plate mounts).
angib wrote:And while it might actually be at least as easy to make a curved hatch and roof, I think the flat panels and sharp corners would provide more people with the encouragement to build a 'teardrop', so it ought to be really popular with first-timers (I won't use the v.... word).
mikeschn wrote:Strangelymade wrote:Please carry on with this, the prototype looks great already, be exciting to see what you'll be using as the frame and wheels.
Nothing fancy with the frame and wheels... Just using a standard HF trailer, that has about 15" chopped off the length... For the really fancy light weight stuff, you have to see Andrew's stuff in the design library!
