bobhenry wrote:No worry about coordinating lifting power as the air pressure would be equal at all lift points.
aggie79 wrote:For my #2 build, I would like a slouch/standy design. Whatever I come up with needs to fit into the garage, so that means a design that allows the trailer height to increase once at the campground.
Lifting a roof only is difficult enough, but lifting a roof with with sidewalls adds additional challenges to racking and uneven lifting. In my current sketches, I have a hybrid roof design with partial front and rear walls that lift with the roof. The partial sidewalls do not lift with the roof. They fold into the trailer and manually would be flipped up in place after the roof is up.
To eliminate side to side racking and to reduce the lifting points from two to one on each of the two end walls, the end wall would be constructed like a drawer with two vertical slides. A single linear actuator would be mounted to the middle of the end wall structure and would raise and lower the end wall.
With the above, a design that has a fixed or rigid connection between the roof and the two end walls would require that the two linear actuators at each end to be synchronized. So instead of worrying about the synchronization, I came around to hinging the top of each end wall to the roof. This way it wouldn't matter if the front wall is raising/lowering at a different speed than the rear wall or vice-versa.
aggie79 wrote:So instead of worrying about the synchronization, I came around to hinging the top of each end wall to the roof. This way it wouldn't matter if the front wall is raising/lowering at a different speed than the rear wall or vice-versa.
