Torpedo - build complete
Re: Torpedo Build 10/19/12
Postby Irmo Atomics » Fri Oct 19, 2012 4:25 am
I fit the hatch on today and yes, we have clearance, Clarence.
(So how exactly did I close the hatch and still manage to get that picture?)
Bob
Irmo Atomics
Images: 64
Re: Torpedo Build 10/5/12
Postby logman7777 » Fri Oct 19, 2012 6:43 am
self timer on your digital camera??? LOL
Coleman Keepers 200A Gang
High Wide and Handsome Probationary Member
Happy Camping!! -Andy
logman7777
Postby logman7777 » Fri Oct 19, 2012 6:44 am
Nice OCC reference too.. :thumbsup:
logman7777
Postby Irmo Atomics » Fri Oct 19, 2012 10:29 am
No Houdini here, I slid up inside the spot for the A/C. I'm still working on a removable panel for that spot; at least I won't need the A/C for a while.
Next major step is to build the cabin doors. I have all the parts to do it, I've just been putting it off.
Now that it's football season, the weekends are less productive. I still plan on having this unit done by mid November.
Bob
Irmo Atomics
Images: 64
Postby logman7777 » Fri Oct 19, 2012 3:28 pm
Looking Good!
logman7777
Re: Torpedo Build 11/5/12
Postby Irmo Atomics » Mon Nov 05, 2012 6:34 am
So I have the skin on and the hatch and roof vent installed
99522
And I used the same hinge set-up for the doors
99521
I got some small windows off of Ebay, cleaned them up and put a piece of stained glass in them. They'll be for ventilation because the round windows will be fixed.
I managed to spend a whole day cutting, grinding, drilling, bending, welding, painting some tail light brackets that will never be noticed once they're installed
99519
(I tried to make them like little teardrops) and here's what they look like on the Torpedo.
99518
I'm almost street legal, just need to install the round windows, finish the aluminum trim, and figure out some hatch supports.
Bob
Irmo Atomics
Images: 64
Postby KCStudly » Mon Nov 05, 2012 6:48 pm
That shape is really looking good with the alum skin on. Nice work! :thumbsup:
Postby Irmo Atomics » Tue Nov 06, 2012 8:31 am
Thanks, KC - it's finally coming together. I put the wheels on yesterday to get it up to ride height so that I could get the hatch supports figured out. Instead of working on the supports, I got distracted and ended up weighing the camper. Since all I have left to finish are the round windows, some alum trim and the hatch supports, I figure the weights are within 10 pounds of the final empty weight.
Total Length tail light to trailer hitch: 140"
Body Height: 52" with 16" of ground clearance to the frame gets me a total height of 68"
Width: 76"
Weight on axles: 800 pounds
Weight on hitch ball: 70 pounds, so I'm a little light on tongue weight, but I've got a plan for that... aluminum suitcases to haul my supplies in:
99535
I'll clean them up and make a tongue mount for them. So my overall empty weight should come in about 900 pounds, not bad considering the trailer frame weighed 220# by itself.
Bob
Irmo Atomics
Images: 64
Postby droid_ca » Tue Nov 06, 2012 10:18 am
Wow that is a good weight congratulations the suitcases are a good idea
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
This one's ready to roll
Postby Irmo Atomics » Fri Nov 09, 2012 8:40 am
It turns out that you can build a teardrop on a budget.
99586
I spent $550 on my frame. That included the cost of the donor popup trailer, extra steel, new hubs, wheels and tires, and a rebuilt suspension.
I spent $700 on the framing and interior finishes. I used 3/4” foam insulation… that should be plenty since I’ll be leaving a window/vent open.
I spent $150 on the electrical. It isn’t very elaborate – AC only – but it’s safe and efficient. One 20 amp main breaker and 2 - 15 amp circuits going to GFCI outlets that protect the galley feed and the cabin feed. I bought a small air conditioner and I got a dorm fridge at a yard sale for $20.
I spent $1000 on the exterior finish. All of my aluminum seams lap over each other and are sealed and trimmed. Every screw hole got a dab of sealant before the screw was installed. Rot won’t be an issue.
99584
So my 6 wide by 9 long (not including tongue) teardrop came in at $2400 and weighs 900 pounds… thrifty, light weight and water tight.
Thanks for the inspiration
Bob
Irmo Atomics
Images: 64
Re: Torpedo - build complete
Postby eaglesdare » Fri Nov 09, 2012 10:11 am
that is really nice! :applause: :wine:
Louella
May the foam be with you.
eaglesdare
Postby LarryJ » Fri Nov 09, 2012 1:59 pm
I like it - all newer components but very retro.
Well done!
:applause:
LRJ
Have Fun!!!
LarryJ
Images: 81
Postby Shadow Catcher » Fri Nov 09, 2012 3:35 pm
Looks great and thinks for the interior shots.
Postby Junkboy999 » Mon Nov 12, 2012 6:02 am
Love the pastel colors and the retro look as well..
Let us all know how it does on it first trip.
Junkboy999
Images: 52
Postby DMcCam » Fri Nov 16, 2012 11:07 am
Very nicely done, gotta love the deco lines!!! You'll be turning heads everywhere! :applause: :applause: :applause:
All the best,
Dave
DMcCam
Users browsing this forum: Bing [Bot] and 12 guests
