Bogo wrote:He might also need help on choosing the sizes of the frame tubes, bolts, etc.. That is where I'm at at this point and the tutorial doesn't cover that.
biziedizie wrote:Were you thinking of going with channel or square tube?
Shadow Catcher wrote:Our 10X6 is all aluminum, wall tubing is 1.5 X 1 X .060 tubing main frame 1.5 X 3 and the tongue should have been heavier (I have had it reinforced). It was MIG welded and should have been TIG You can see its construction in the album. Have you decided on axles yet?
Bogo wrote:The 6061-T6 has a similar yield strength to the mild steel mentioned in the tongue strength page.
angib wrote: For commercial builders, this isn't a big issue, as they have experience of making many frames over a long period, so they know what works.
For the amateur, the only way that I can see to make a safe aluminium frame that will last for years is to make it really strong - but then it won't weigh much less than a steel one and will probably cost more. So why bother?
