TV
TV
Postby XcessiveCarts » Sat Oct 20, 2012 9:01 am
I am building my first Cargo Camper. It is a Haulmark 6x12. I want to install. HD TV, and need I of on selecting a antenna. I know it has to be mounted outside. I want something small, cheap, but effective. Any Ideas????
XcessiveCarts
Images: 9
Re: TV
Postby 8ball_99 » Sat Oct 20, 2012 9:39 am
I have a LCD in my cargo trailer. I went with a Roadstar 2000 OminDirectional antenna.. Works great, no adjusting, pointing, ect.. Mount it on the roof and you never touch it again.. Cost was around 100 dollars online.
Here is what it looks like on the roof.. Ignore the mess the photo was taken when I was installing the solar panels
8ball_99
Re: TV
Postby CurtMarsh » Sat Oct 20, 2012 4:05 pm
that antenna has an amplifier built in to it. There is a twelve volt power source that mounts on the wall or ceiling on the inside of your unit. they are connected by a piece of coax antenna cable. The coax carries the 12 volt up to the antenna and The signal from the antenna to the inside. you then have a peice of coax going to the TV set. I put on on my airstream and here in the Tampa area could pick up more than 20 stations The only thing is you must have a 12 volt line going to the power supply unit. Curt
CurtMarsh
Re: TV
Postby flboy » Sat Oct 20, 2012 6:20 pm
I used a little digital antenna I got offline for $59.00. It comes with cable, rotator and power supply. I mounted it on an old camera tripod. Works great! It comes off for travel (held down with bungee strap) and takes about 2 minutes to set up. THe cable just runs through the back door seal. I set it up after the bikes come out.
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Re: TV
Postby Shadow Catcher » Sat Oct 20, 2012 6:35 pm
We have both a Jack antenna and a dish for satellite, both use the same mast. The suction cup mount works great.
86638
86637
Re: TV
Postby David_L6 » Sat Oct 20, 2012 7:02 pm
flboy wrote:I used a little digital antenna I got offline for $59.00. It comes with cable, rotator and power supply. I mounted it on an old camera tripod. Works great! It comes off for travel (held down with bungee strap) and takes about 2 minutes to set up. THe cable just runs through the back door seal. I set it up after the bikes come out.
I have the exact same thing as flboy. He told me what and where to buy and I did. Thanks flboy. :thumbsup:
David_L6
Images: 16
Re: TV
Postby 8ball_99 » Sat Oct 20, 2012 10:17 pm
CurtMarsh wrote:that antenna has an amplifier built in to it. There is a twelve volt power source that mounts on the wall or ceiling on the inside of your unit. they are connected by a piece of coax antenna cable. The coax carries the 12 volt up to the antenna and The signal from the antenna to the inside. you then have a peice of coax going to the TV set. I put on on my airstream and here in the Tampa area could pick up more than 20 stations The only thing is you must have a 12 volt line going to the power supply unit. Curt
Exactly what he said.. It comes with a wall plate that has a 12v outlet on it and a on off switch.. On the back of the wall plate it has a connection for 12v the antenna and to the TV.. On the front of the wall plate it also has another connection for a TV. Everything you need plus instructions comes with it.. It needing the 12v is a good thing. A powered amplifier will give you better reception then the same size antenna with out one..
8ball_99
Re: TV
Postby 8ball_99 » Sat Oct 20, 2012 10:18 pm
biziedizie wrote:So I never knew one could get that many channels!
Do sat dishes cost money to receive? I'm inept when it comes to this stuff :shock:
Yes, just like cable..
8ball_99
Re: TV
Postby Riken » Sun Dec 02, 2012 11:56 pm
I am interested in that digital setup. Can you share where you ordered that setup online? TV is not a necessity but a bonus to have when trying to settle kids down for midday nap.
Thanks
Riken
Re: TV
Postby nuclearfly » Mon Dec 03, 2012 1:32 pm
As far as I know, there is no real difference between digital antennas and analog antennas. It all comes down to the tuner.
I have an antenna on my house, and I think I only paid about $30 for it. Here's a good site with a lot of info regarding antennas, and it can provide you with a heading to point your antenna if its directional.
http://www.antennaweb.org/
nuclearfly
Re: TV
Postby Riken » Mon Dec 03, 2012 5:12 pm
Thanks
I am familiar with that website. I was interested in the type of antenna you had. I like that setup and was looking for something like that compact and easily portable. I do have one at home now. Its a channel master I believe. Its pretty good just doesn't seem to receive all the channels I should be receiving via antenna web's recommendations. Could be the digital box? I have had two different boxes give different receptions as well as two different antennas.
Riken
Re: TV
Postby Wolfscout » Tue Dec 04, 2012 5:50 pm
I suppose someone might want to spend couple hundred dollars for a nice fancy-smancy antennae.
I found the plans for mine online and did this:
Which gave me this nice picture:
I updated later to a HD TV and it's still a great picture. Several local channels at a pop for news and weather. Who really needs more?
Larry Fulmer, Jr.
CTC 2
Wolfscout
Images: 32
Re: TV
Postby rando18 » Wed Dec 05, 2012 8:46 pm
This may be what your looking for.
Read the reviews.
I have one in my house and it works great.
They are called over the air antennas (ota).
I don't have TV in my 7x14 CT.
XM radio is all I need!!!
http://www.amazon.com/gp/product/B006GQ ... 01_s00_i00
rando18
Re: TV
Postby flboy » Fri Dec 28, 2012 12:45 am
Sorry, I haven't been out to this site in a few weeks. I got my antenna from these folks. It works great. I am buying another for my house. I like having backup if cable goes out and some stations are much better HD off the Air.
http://www.homeantenna.org
rando18 wrote:This may be what your looking for.
Read the reviews.
Don (Flboy)
flboy
Images: 378
