Slide on Tear
Slide on Tear
Postby greg55 » Sat Mar 25, 2006 6:07 pm
I read about someone building a slide on tear.I have a snowbear 7000 utility trailer that I could use as a slide in.Since the whole thing will be sliding on and off the utility trailer what would be a good way to build the floor so it will be light and strong enough to keep the whole unit from twisting when moving on and off.I was thinking 1/2" MDO ply for the walls and 1/8" inside and out for the top.I'am trying to be as light as possible as the trailer weighs 348 lbs empty and will be pulling with a 4 cyl auto.
greg55
Postby ARKPAT » Wed Mar 29, 2006 6:06 am
You might looking at the bottom of this thread.
http://tnttt.com/viewto ... ty+trailer
and for lite Tear a versions of these maybe usable.
http://tnttt.com/viewtopic.php?t=7275
and
http://tnttt.com/viewtopic.php?t=7565
I hope this helps. :)
And as Madjack said pictures - pictures - pictures.
:snappy: :snappy: :pictures: :pictures:
Pat
Life is to short always eat dessert first.
ARKPAT
Images: 77
Postby greg55 » Wed Mar 29, 2006 8:09 pm
Thanks Pat.I should be able to come up with something after reading that info.
greg55
Postby fornesto » Thu Mar 30, 2006 11:28 am
If you're snowbear trailer is like mine, it has removable gates. You might use stakes built into the teardrop and reuse the gate holders. If you used a wedge system you could really tie the slide-off down.
fornesto
Users browsing this forum: Google [Bot] and 4 guests
