xxl grommets
xxl grommets
Postby droid_ca » Sun Oct 28, 2012 9:55 am
I'm looking for a source to order the 4 inch grommets that are commonly used on interior curtains... I have no clue where to start looking
Thanks ....
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Re: xxl grommets
Postby asianflava » Sun Oct 28, 2012 2:44 pm
Don't know exactly what you need them for, but you could split rubber hose and use it as a grommet.
asianflava
Re: xxl grommets
Postby droid_ca » Sun Oct 28, 2012 5:51 pm
I would like to use them for exterior curtains for a potty room outside my trailer
“Fide Canem”
droid_ca
Images: 176
Re: xxl grommets
Postby Sandyman » Sun Oct 28, 2012 6:43 pm
Look for shower curtains hooks or better still just sew Loops on the top of the curtain and slide the rod through them. You can make the loops any size.
Sandy C :D (Not related to the storm!)
Sandyman
Re: xxl grommets
Postby droid_ca » Sun Oct 28, 2012 11:10 pm
Sandyman wrote:Look for shower curtains hooks or better still just sew Loops on the top of the curtain and slide the rod through them. You can make the loops any size.
That is a great idea thank you for that I would of been looking forever for those grommets and they probably would end up rusting on me...Hahahahahaha thank you for that :applause: :applause: :applause: :applause: :beer:
“Fide Canem”
droid_ca
Images: 176
Re: xxl grommets
Postby Treeview » Mon Oct 29, 2012 4:26 pm
Four inch inside diameter???
Why so big?
Could you cut rings from 4" PVC tubing in small slices that would fit through the largest grommet you can find to attach to the curtain? Split the PVC, slip it through the grommet and reglue the PVC into a ring.
Treeview
Images: 30
Re: xxl grommets
Postby Sandyman » Mon Oct 29, 2012 7:19 pm
Droid, Glad I could help. Good luck
Sandy C :D
Sandyman
Re: xxl grommets
Postby mcspin50 » Tue Oct 30, 2012 6:11 pm
Large grommets might be available at a fabric store, like JoAnne's, or upholstery shop. JoAnne's might be cheaper.
You could also sew big buttonholes in the top hem and slip the rod through them. Just make it an odd number so it folds evenly.
HTH
Lil M.
In every walk with nature, one receives far more than he seeks. - John Muir
Generic Benroy Build Journal here - My LilScamper Update Journal here
The Lily Pad...Image My LilScamper...Image Image
mcspin50
Images: 158
Re: xxl grommets
Postby droid_ca » Tue Oct 30, 2012 7:22 pm
mcspin50 wrote:You could also sew big buttonholes in the top hem and slip the rod through them. Just make it an odd number so it folds evenly.
HTH
Anoher good idea Thank You
“Fide Canem”
droid_ca
Images: 176
Re: xxl grommets
Postby flyinglow » Tue Oct 30, 2012 10:50 pm
flyinglow
Re: xxl grommets
Postby droid_ca » Tue Oct 30, 2012 11:07 pm
flyinglow wrote:Like these?
http://www.kingrichardco.com/draperygro ... efault.htm
http://www.beaconfabric.com/vindex.html?cat290.htm
Yes thats them, thanks now I got a few ways to try thank you for finding those and pointing me in the right direction
“Fide Canem”
droid_ca
Images: 176
