droid_ca wrote:
So if you want to do this ask the hardware store about if it is safe to drink and make sure you get the right glue as some can make you sick
This a well documented and studied problem that the home bath fixture industry is well aware of. The problem has to do mostly with the standing water in the pipes. You can never get all of the water out of those pipes, and they WILL bread microorganism. We paid to have test run on these pipes, and found staph and e-coli in the pipes. Lost my share of the company in the 08 crash when the creditors took over , but more info can be found at sanijet.com. Just don't go look if you have a jetted tub, and ever want to use it again... Scary stuff.
Wobbly Wheels wrote: I now shudder to think of what else might have been sharing the hot tub with us !
So thanks for that, Wes: you have forever removed the romanticism of our 'little cabin in the woods'.
