Faux shepherds hut
Faux shepherds hut
Postby planzman » Fri Nov 02, 2012 7:50 am
I stared this over in non -traditoinal designs
you can read my about my quest here.
viewtopic.php?f=5&t=52390
but, here is where I will put my build journal.
It all started with wanting a simple camper for the hunting club. My son(s) and I go hunting almost every weekend from Mid Oct through late Jan. We wanted to keep warm and have a place to store stuff that was more secure than a tent and would have a shower and maybe a wood stove for heat.
we started looking for a camper and were ofter beat to the buy by other hunters. We were disgusted with the junk that people whould put on the market, thining that by puting the words "hunters special" it would be worth buying. What junk! and smelly too.
so we decided it would be better to build on an existing frame.
we found this frame on craigslist for about $220.
1 junky.jpg (40.92 KiB) Viewed 1614 times
3 nasty floor.jpg (28.03 KiB) Viewed 1614 times
planzman
Re: Faux shepherds hut
Postby planzman » Fri Nov 02, 2012 7:51 am
we removed all the rotten ply and subfloor and ground off all the rust.
we then put on a coat of primer
5 primed rear.jpg (50.82 KiB) Viewed 1613 times
6 primed front.jpg (52.28 KiB) Viewed 1613 times
planzman
Postby planzman » Fri Nov 02, 2012 7:53 am
after letting the primer dry overnight, we put on a coat of black gloss paint.
8 side black.jpg (72.4 KiB) Viewed 1613 times
7 rear black.jpg (82.41 KiB) Viewed 1613 times
9 black frame.jpg (130.73 KiB) Viewed 1613 times
planzman
Postby planzman » Fri Nov 02, 2012 7:55 am
once the paint dried, i moved it inside to start leveling and collecting materials.
The are still building in my sons neighborhood, so he got permission to collect the discarded mylar duct from a new house.
10 barn.jpg (47.04 KiB) Viewed 1613 times
planzman
Postby planzman » Fri Nov 02, 2012 7:57 am
the original subfloor was just plane untreated wood, so we wanted this to last for a long time. We went with pressure treated and bolted it down.
12 sub floor.JPG (141.09 KiB) Viewed 1613 times
11 subfloor frm.JPG (115.4 KiB) Viewed 1613 times
11 subfloor frame.JPG (138.22 KiB) Viewed 1613 times
planzman
Postby planzman » Fri Nov 02, 2012 8:00 am
the original trailer had a holding tank, which we discarded and framed over the space.
we wanted a good weather proof floor, so we went with half inch pressure treated ply.
16 floor.jpg (46.19 KiB) Viewed 1613 times
14 half floor.jpg (43.79 KiB) Viewed 1613 times
13 ply.JPG (138.88 KiB) Viewed 1613 times
planzman
Postby planzman » Fri Nov 02, 2012 8:03 am
started framing, which if done by yourself is sorta like juggling eggs. :x
17 building camper.jpg (49.75 KiB) Viewed 1613 times
so my son came in and i got him to help me level and get every thing plumb
20 cross frame support.jpg (39.39 KiB) Viewed 1613 times
19 door side frame.jpg (24.59 KiB) Viewed 1613 times
planzman
Postby planzman » Fri Nov 02, 2012 8:29 am
as we progressed with framing, we wanted to cover up the old metal wheel wells.
26 wells.JPG (136.18 KiB) Viewed 1612 times
and i built a door from some left over 3/4 inch pressure treated ply
so it was time to start thinking how to bild the roof and how tall it was going to be. My cieling is higher than the barn door. :shock:
24 its gonna look good.JPG (135.75 KiB) Viewed 1612 times
27 door.JPG (131.24 KiB) Viewed 1612 times
planzman
Postby planzman » Fri Nov 02, 2012 8:33 am
so I now knew how long and tall the arch would be, it was time to make one.
28 measureing height.JPG (100.66 KiB) Viewed 1611 times
here is the first protype in place.
the notchs on tope are for perlons running fore to aft.
29 fished arch.JPG (143.24 KiB) Viewed 1611 times
30 arch and bed.JPG (147.44 KiB) Viewed 1611 times
planzman
Postby planzman » Fri Nov 02, 2012 9:11 am
so it was time to start hangin some metal
30 arch and bed.JPG (147.44 KiB) Viewed 1609 times
first we covered with a house wrap for moister control.
once i got both the front and back covered with metal, i an out of room, it had to go....outside that is.
32 at the door.JPG (127.25 KiB) Viewed 1609 times
31 downsize (11).jpg (63.51 KiB) Viewed 1609 times
planzman
Postby planzman » Fri Nov 02, 2012 9:21 am
my door has a header that is lower than the cieling, so i had to let the air out of the tires to ensure it would clear
33 tight.JPG (98.98 KiB) Viewed 1606 times
33 starting out.JPG (81.34 KiB) Viewed 1606 times
34 finaly out.JPG (107.64 KiB) Viewed 1606 times
planzman
Postby planzman » Fri Nov 02, 2012 9:31 am
so now it will rest overnight so i can start putting on end walls
37 outside first time.JPG (94.95 KiB) Viewed 1603 times
36 outside for the night.JPG (105.23 KiB) Viewed 1603 times
planzman
Postby planzman » Tue Nov 13, 2012 8:13 am
everything went real fast last couple of days, so not a lot of pics of the progression.
here is where we finished it up enough to be road worthy (we hope)
and where it wound up at the deer club
cabin in the woods.jpg (51.1 KiB) Viewed 1496 times
we have some more work to do inside, but we do have heat and some light
light and heat.jpg (238.27 KiB) Viewed 1496 times
planzman
