Hello all, newbie here. I'm a vet motocrosser from the New England area and I am about to embark on my first build. I currently have a 6x10 that I outfitted with some cabinets and bins, an inverted, 15A inlet plug and some other minor mods but I am selling that and stepping up to a 7x16 that I plan to convert into a toy hauler complete with a shower. I will definitely document my build and share it here with you folks since most of what I have learned has come from lurking here for a while.
Anyway, on to my first question. I want to start with a quality trailer so I have a good foundation. I am leaning towards a Haulmark Grizzly. A friend of mine told me to check out the Car Mate Custom Cargo series. When I did, I found out that the walls are made of 2x3 wood studs rather than steel tubbing or hat channel. Is this a case where they have discovered a great technique that no one else is using or is this not as robust as steel and they are cutting corners? The one advantage to wood is that you don't have the steel there to heat sink the sun which will make it easier to cool but its not worth it if its a poor design otherwise.
Thanks.
