What trailer is best to start with?
Postby E. Aaron Scott » Fri Nov 09, 2012 5:48 pm
Just pitching around a few idea on a Teardrop and was wondering what is the best trailer to start with? I found this one http://www.northerntool.com/shop/tools/product_200356494_200356494 it $500 with a 1,700 payload. If anyone knows of a better one, please let me know.
Thanks
Aaron
-Aaron KF5VBV
E. Aaron Scott
Images: 9
Re: What trailer is best to start with?
Postby 48Rob » Fri Nov 09, 2012 7:12 pm
Hi Aaron,
Best trailer, or cheapest trailer?
In order to choose a trailer, you should have at least a general idea of what you want to build.
Size, weight, etc.
Do you want leaf springs, or torsion springs?
Once you know what you want to build, you can decide on a trailer that closely matches what you need, unless you plan to heavily modify one, in which case you're better off building, or having built, a custom trailer.
Rob
48Rob
Postby E. Aaron Scott » Sat Nov 10, 2012 2:55 pm
I was just thinking about something to get started with. Perhaps something like a Benroy.
-Aaron KF5VBV
E. Aaron Scott
Images: 9
Postby asianflava » Sat Nov 10, 2012 7:25 pm
You also have to consider any possible modifications that a bolt together trailer may need. I've seen some people start with a run of the mill HF trailer, but by the time they've widened it, replaced the coupler, changed axles, and installed bigger tires they would have been better off just starting with a custom frame.
If you know someone who can weld it up for you, custom is the best way to go because it doesn't cost too much more (as long as you don't get carried away) plus it will be exactly what you want.
asianflava
Postby Lgboro » Tue Nov 13, 2012 7:55 pm
I started with a Tractor Supply (CarryOn) and could have built a custom after the mods I made. If I were to build again I would build a custom trailer .
Lgboro
Images: 53
Postby rowerwet » Mon Jan 28, 2013 5:36 pm
having built on a tractor supply no-floor trailer ($360) two tent trailers (PUP) given to me last year for nothing, just come pick them up, I would really recommend finding an old PUP on craigslist, ebay etc.
First of all, a PUP frame is normally 5' wide, IMO the perfect width for a TD, this will take away any headaches with how to support the overhang (you really don't need to anyway, the nose wall and galley wall are all the support the TD needs)
PUP frames are already built strong enough to stand on and still be light to tow, you will only be sleeping on it with your weight spread out by a mattress, put your floor on the frame and build away.
Most PUP's frames will also let you have a 10' length, with no axle moving worries, another plus in my book.
A PUP on craigslist in worn out, mouse infested condition should be free or nearly free, however it should come with plenty of usefull stuff, the one I tore down for a utility trailer netted me a collection of lights, a power center (110 to 12v), sink, faucet, ice box, fire extinguisher, door latch, draw latches, awning track, and some other stuff I can't think of right now. It also has a nice torsion axle. between the money all that stuff would cost even on Ebay, I will always be recommending just using a PUP frame from now on.
also forgot to mention the nice pile of scrap metal from the PUP teardown, a few more dollars in the pocket
rowerwet
Images: 521
