I have been thinking about a cargo conversion, but I just love TD's and the price tag for a cargo trailer is putting me off. So I stumbled upon the Campster 12 (thanks for the design Grant) and it fit my needs a little better. I realize that my needs for a trailer are a little unique. Mainly I need a trailer that will fit me and my wife plus two growing children. Another requirement is it will also need to carry my Telescope and Astronomy Gear. The Campster 12 will fit the sleeping and setting arrangements very well. However my telescope is a different story. To let you know the telescope breaks down into 2 parts. The Tube and Base. The Tube is 14" in diameter and 5' long. The base is 2 1/2 feet in diameter and three feet high. The scope can not just ride in the living quarters because it will have to be taken out while we sleep and that will not be good, so it will have to have its own storage in the trailer. The only place that I can think of to put it would be in the galley. I was thinking of building a slide out box that would take up the place of the lower cabinets under the sink. This would end up taking out most of the storage space in the galley and my wife would frown upon that
I also thought of building a cargo box that would go on the roof but the thought of lifting a 100 lb telescope that high up is very painful.
Another problem is the frame. This will have to be built on the cheap and the frame gives me problems. I am a very good woodworker with nearly a full shop but I have no experience in working with metal. Also contracting out the frame build could end up getting very expensive. So I was wondering if there was a trailer like the 5X8 and Northern Tool that I could modify to make it work.
Also my tow vehicle is a 93 Chevrolet 1500 with a tow limit of 6,500 lbs so I don't think that will be a problem for a TD even a large one.
Now put your gears in motion and try to help me come up with a solution. I'm open to any and all ideas but I would really like to have a teardrop shape.
Thank You
Aaron
