doug hodder wrote:If dry camping, you can always drain the cooler and use it for dishwashing to stretch your water supply. Not all that great if you have any "leaking" packages of stuff in it though. Doug
bdosborn wrote:We boondock quite a bit as well and the propane water heater is surprisingly efficient. The standing pilot light is more than enough to keep the water hot. We use a single 20# tank of propane a season and most of that goes to the BBQ and the stove. I added a valved hose to the hot water heater so we can wash the dutch oven with hot water as well since the sink is little small for that. It helps when draining the system too.
Mukilteo wrote:Why not route the heat exhaust from the water heater through some sort of heat exchanger.
There is a lot of waste heat coming out of it.
