light weight PVC construction & 0ther ideas
Postby droid_ca » Mon Dec 03, 2012 1:32 pm
After deciding that I wanted to be able to haul my trailer with the smaller of my vehicles I needed to research light weight designs so I think I found pvc to be my solution and thought I'd share some of the information that I have found
http://www.ehow.com/how_7481809_build-l ... ailer.html
http://voices.yahoo.com/diy-build-own-u ... 97006.html
http://www.weiscrafttrailers.com/articl ... hneck.html
http://www.weiscrafttrailers.com/firefli.html
http://www.gunlakepaddlesports.com/trailers.htm
http://home.howstuffworks.com/home-impr ... railer.htm
http://bonnaroo.proboards.com/index.cgi ... read=27499
http://www.ehow.com/how_12012764_build- ... elter.html
if you know of any other ways or ideas pleas share thank you
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Re: light weight PVC construction & 0ther ideas
Postby bobhenry » Tue Dec 04, 2012 7:01 am
For straight runs of 3/4 pvc if you insert 1/2 E.M.T. tubing inside it is almost unbendable.
You may need to lube it up to insert longer sections together.
Postby droid_ca » Tue Dec 04, 2012 1:41 pm
what about 11/4 tubing as that is something I think might work a little better for my needs
“Fide Canem”
droid_ca
Images: 176
