A question was asked some time ago about thickening epoxy resin. I couldn't remember the name of the stuff I used but here is all the good stuff about it.The thickening agent is called Cabosil and is the greatest stuff since sliced bread. It is the perfect stuff to use in wood if you have a thru hole for a bolt and don't want water to creep inside and cause dry rot. The way to do this is drill the hole at least 5 mm greater than the dia. of the bolt, then fill with epoxy thickened with Cabosil. When it is cured, re-drill the hole to the size of the bolt. No water will be able to seep into the wood as the epoxy/Cabosil has sealed the timber perfectly. It's the best stuff for use in thru boat hulls for attaching a towing point for skiers and similar. It is immensely strong.
http://www.epoxysystems.com/71.htm
To clean your hands or brushes after using epoxy resin, wash your hands etc. with a cheap white vinegar. Vinegar on a cloth is perfect for wiping up smears of resin when it is spread on your work areas or where a resin "run" has occurred on your job.
This agent is the perfect thing to use when filling screw holes, it does not crack off or fall out and does not shrink. I have never had a failure with it. It cost about $45.00 for a pound but a pound takes up a huge volume as it is so light. If you want some, try and go halves with your buddy. You will never regret using this stuff.
Kody
