So my TT is about complete (on my computer at least), and I would love some input from everyone in this excellent forum. The overall idea is to make a woody with 1/8" skins covered in epoxy and varnish. I am building on a Northern Tool 5 x 8 trailer which happened to arrive today! This is a winter project and I am looking forward to next year's camping season and some road trips!
Update: I have started the build! Build Journal here:
http://www.tnttt.com/viewtopic.php?f=50&t=53842
Update: More pics added!
I hear you guys like pictures!
Overview:
I'm hoping 6' 4" of cabin length will be enough. I'm 5' 10" so I think that should be fine. I plan on using prefab doors from teardroptrailerparts.com. I have made designs based around a 4" mattress and the door installed with a 2" threshhold.
As far as wiring goes I will just have a 12v system powering a Fan-tastic fan, porch, galley, cabin lights, and a couple 12 volt sockets. The battery will be in a battery box on the trailer tongue and the fuse box will be behind the galley in a small compartment near the roof.
Sidewalls:
For my sidewalls I am using "skeletonized" 3/4" ACX ply sandwiched between 1/8" skins and insulation in the voids. The inside will be birch but not sold on the outside yet. I may also leave myself some room to use 1/4" ply on the outside as I am finding it easier to locate more varieties of wood in that thickness. The walls will overhang the frame.
Since the trailer is ~9' I am not decided on how to make the sidewalls. 4 x10 is not available in my area so I will be constructing them from 4 x 8 ACX. I will probably use a lap joint or laminate 1/4" and 1/2" sheets, staggering the sections for strength. This might work better than a lap joint as I can skip cutting the 1 5/8" wide and 1/4" deep mortise in the sidewall and instead cut each ply sheet to include that offset before laminating.
Hatch:
Sidewall Hatch Notch:
Here is the notch for the hinge on the sidewall. I plan on using a hurricane hinge with no offset. I have left 3/8" for a seal and a U channel.
Roof:
I am using Steve's method of inside-out building. I plan on using 1 x 2 poplar spars, sandwiched between 1/8" birch and insulation in the voids. The headliner will rest on the 1/4" shoulder of the sidewalls and the spars placed over.
Floor:
The floor is a sandwich of 1/4" ACX and framed with 1 x 4 poplar. It overhangs the frame lengthwise a few inches. Since I'm using 4 x 8 ply for the floor I guess I will have to use 3 pieces for each layer.
Cabinets Galley:
I am using 3/4" birch for the counter, bottom of the cabin cabinets, and the bottom of the front cabinets and 1/2" for everything else. I was thinking it might be good since they will be holding more weight. I might reconsider and do everything using 1/2".
Cabinets Back:
Cabinets Front:
Here are the front cabinets. It is hard to see but I will have a hamper or large storage compartment in the bottom which is accessible from two separate door which open upwards located in the middle.
Side Overlay:
Here I have overlayed the sidewalls, cabinets, roof, and hatch. You can see there are supports in the walls where the cabinets meet he sidewalls and floor supports. I left 3 inches of sidewall material on either side of the cabinets for blocking and support.
Good or bad I would appreciate any advice, questions, or concerns. I have borrowed/stolen so many great ideas from everyone else's builds that I have hopefully saved myself some headaches.
Thanks again!
Cheers,
Ryan
P.S. I used SketchUp for 3D modeling if anyone was interested. It's a really great program.
