by STORMRIDER151 » Thu Dec 13, 2012 12:33 am
I'm installing a PD4000 60 amp power converter in my build. I have it wired up per the installation guide but something seems to be missing. On the lower right side of the AC side there is a bus bar that is labled out to converter. It was prewired to the converter but nothing going in to the bar. The guide says nothing about a power feed to the bar. I'm thinking that this would be treated as a branch cirquit with a jumper from a cirquit breaker to the bar. Or am I completely off base. I currently have a 30 amp main breaker, Two 15 amp breakers going to GFCI protected cirquits and a 15 amp GFCI breaker going to the outside receptical. The box will not accept any more breakers. if I'm on target with the jumper should I simply come off one of the breakers with a 10 awg wire to the buss bar or call an electrician? I hope i've made sense. If I did it will be a first. Now all I need is a battery, a fire extinguisher and some marshmellows. Thanks for the help.
