I am getting to the point in my build where I need to consider the type, coating, and length of screws on the build. Specifically I am curious about the screws to attach the sidewalls to the deck and roof spars.
I am building sandwich walls |1/8"| 3/4" |1/8"| so the screw heads will be covered by the outside skin (not to mention epoxy and spar varnish outside of that). Check my design thread for more pictures.
My question is what type of wood screws would you all recommend? What length? And does it matter if they are zinc, galvanized, or SS if they will never be exposed? Zinc is by far the easiest to come by around here.
Thanks!
