Kody wrote:The very best and safest material for holding the keel onto the boat is silicon bronze or monel. Stainless Steel is never used as keel bolts here in Oz by any yachties that I know. Silicon bronze is expensive but you can trust it with your life as a bolt for attaching the keel.
I have seen SS bolts completely wasted away from corrosion (3/8" dia down to 1/8" dia.) but the hexagonal head and nut still looked perfect. It's bad news stuff if your hoping to use it for protection against corrosion in a wet area and especially in timber that is often underwater.
Kody
The corroded area of the SS keel bolt nut I posted a pic of was on the underside against a washer and the hull. From the top it looked fine.
Cheers,
Gus
