120V submersible pump experiment. Is it safe???
Anything electric, AC or DC
Postby Chuck Craven » Mon Apr 03, 2006 6:35 pm
ENDO
Go ahead and use the pump, it’s designed for water!
My well pump is run on 220 and no GFI protection and has a plastic pipe to the house.
I would wire it after the GFI outlet and put in a dedicated 1 amp fuse.
You can get a fuse holder from an electronic supply house. It has a screw cap with the fuse under it. As to grounding the sink and faucet! Why? If your house has plastic pluming, they don’t ground the sink or faucet!
Chuck
Chuck a new td builder
Chuck Craven
Images: 62
Postby kirtsjc » Mon Apr 03, 2006 6:45 pm
Miriam C. wrote:if you use anything with electricity in a way it was not intended on a source you have not checked you will someday be a nominee for the Darvin award.
ALL RIGHT, a fellow Darwin Awards follower!
Ok, back from my thread madjack, and following this discussion with interest...
BTW, has it occurred to ANYONE to simply look at a long-established manufactured unit (Oh, Airstream comes to mind) to see and follow what they do? After all, THEY have to follow codes, and WE should benefit from observation...
kirtsjc
Images: 43
Postby madjack » Mon Apr 03, 2006 6:49 pm
...in all of these arguments there is one fact that has been sorely overlooked...This pump is not meant for pumping of water for human consumption and for no other reason BUT that one, I would steer very well clear of it...as an added aside...if possible I would avoid mixing ACV and water...I grew up with water wells...have also worked on them as a plumber and have been knocked on my butt more than once by some errant electrons...
madjack 8)
Postby Chuck Craven » Mon Apr 03, 2006 7:21 pm
OK now we know why Jack is MAD!!
He forgot to turn off the power before playing in the well! :lol:
I guess I didn’t look closely at the information on the pump! :oops:
What is the pump meant for like fish tanks? It does not say it can’t be used for drinking water but it doesn’t say it can. :NC
Chuck
Chuck Craven
Images: 62
Postby madjack » Mon Apr 03, 2006 7:31 pm
Chuck Craven wrote:OK now we know why Jack is MAD!!
Chuck
oh but I did and it was wired incorrectly and POW and had it happen more than once(or some form or another)
Chuck Craven wrote:It does not say it can’t be used for drinking water but it doesn’t say it can.
...if it does not have a NSF potable water rating BEWARE ...is all I am saying...
madjack 8)
Postby Chuck Craven » Mon Apr 03, 2006 7:43 pm
madjack wrote:...if it does not have a NSF potable water rating BEWARE ...is all I am saying...
madjack 8)
Yes Jack is right!!!!
Some plastics have led in them. Like garden hoses.
If you are using a garden hose for filling you tank or at the campground look for one that is rated for palatable water usage. :applause: :applause:
Chuck
Chuck Craven
Images: 62
Postby Miriam C. » Mon Apr 03, 2006 7:44 pm
trying to explain the theory behind gynacology(sp)
Cheers
Paul
:rofl2: :rofl2: :rofl2: :rofl2:
You mean there's a theory. Gotta get out more.
Chuck
Campground ain't a house. Nuff said.
Mad Jack :D Glad your back. You seem to be looking younger than your av.
:lol: Miriam
Postby madjack » Mon Apr 03, 2006 7:47 pm
Miriam C. wrote:Mad Jack :D Glad your back. You seem to be looking younger than your av.
:lol: Miriam
...thank you, the time and money spent at the clinic must've worked :o :lol: ;) .......................... 8)
Postby Chuck Craven » Mon Apr 03, 2006 7:49 pm
Yes but they are sill under the same basic building codes!
I have seen many a licensed electrician make mistakes in wiring up the simplest circuit!
Chuck
Chuck Craven
Images: 62
Postby Miriam C. » Mon Apr 03, 2006 8:41 pm
Chuck, Thank you for making my point.
Chuck
Postby Chuck Craven » Mon Apr 03, 2006 9:06 pm
Just remember the federal code is the minim required. Any state can write a code that is stricter that the federal code. And any municipality can write a code stricter than the federal or state code. But it applied only to that municipality/state and does not necessarily apply to your camper! There are originations that have written codes too, thay have to meet the federal code or better but only apply to those that belong to that origination. Such as campers, boots, air plans and exc. :?
Chuck
Chuck Craven
Images: 62
Postby TomS » Mon Apr 03, 2006 9:30 pm
:noyes: Enough!
This thread has degenerated into a pissing contest.
Tom Swenson
[email protected]
TomS
Postby An Ol Timer » Mon Apr 03, 2006 9:33 pm
Thank's Tom,
I'm glad someone has balls enough to put the kid's to bed and stop the petty argueing!!!!!!!!!!!!!!!!!!!!!!! :applause:
An Ol Timer
Postby Miriam C. » Mon Apr 03, 2006 9:33 pm
Sorry.
Guess I shouldn't make a joke, huh :(
Postby mikeschn » Mon Apr 03, 2006 9:33 pm
Aw geeze... can we stop the pissing contest already...
Return to Electrical Secrets
