Whatcha do on your build today?
Re: Whatcha do on your build today?
Postby droid_ca » Sat Jan 19, 2013 2:55 pm
biziedizie wrote:3 1/2 hours will be a breeze! I'm looking for a co-pilot as I really don't know how I'll feel after the last surgery.
What I need to do is map things out as for camping places.
I've been looking online and it seems that most places are provincial which means screaming kids which I don't want to be around.
Camping, fishing and peace and quite are my things.
Well depending on when you are going it's really nice around here free firewood outhouses and no charge can't guarantee the non screaming kids but they usually don't stay long...all depends on where you want to go
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Postby Vedette » Sat Jan 19, 2013 3:57 pm
Sitting on the couch again when I should be out tin the shop working on my table?????
But even though there is no Football today. The Barrett-Jackson is on so I have been glued to the set since Tuesday.
1400 cars going thru this year!
Good Roads
Brian
PS
2012 Copo Camaro just sold for $400,000.00
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby jeff0520 » Sat Jan 19, 2013 4:02 pm
I finished up the air conditioner mount. Next step will be to lay out the plan for internal cabinetry, then I'll be installing vinyl flooring
Hypno-Toad's Command Post, the build thread! http://www.tnttt.com/viewtopic.php?f=50&t=50384
jeff0520
Images: 128
Postby _Ryan_ » Sat Jan 19, 2013 6:25 pm
Finished my walls and got everything ready for cabinets. Its really coming together!
_Ryan_
Images: 356
Postby bdosborn » Sat Jan 19, 2013 6:44 pm
I needed to exercise the generator so I started it up and made a cup of coffee. Ran the diesel heater for a little bit as well to make sure it was still working.
Images: 806
Postby doug hodder » Sat Jan 19, 2013 8:20 pm
Made 1 side for the new build...Doug
Postby Vindi_andy » Mon Jan 21, 2013 11:16 am
Glued some of the locking round the edge of my profile That was yesterday will be doing some more tonight
Tried to order a sliding window and will be ordering a door later
Boys never grow in to men the toys just get more expensive and more dangerous
How true :)
Vindi_andy
Images: 49
Postby Vedette » Mon Jan 21, 2013 11:45 am
Work day in the shop for me....just heading out the door.
Brian
Good Roads
Brian & Sandi
Vedette
Images: 443
Postby Vedette » Mon Jan 21, 2013 11:46 am
doug hodder wrote:Made 1 side for the new build...Doug
Doug
Please tell me about the tail lights on your "Rocketear" project????
Brian
Good Roads
Brian & Sandi
Vedette
Images: 443
Postby doug hodder » Mon Jan 21, 2013 6:52 pm
Those are '59 Caddie taillights. I turned a rocket shaped body on the lathe, and routed 2 grooves into it and slipped in fins. Ran it through the band saw to give me 1 flat side for mounting. Coated it all out with epoxy and thickened epoxy fairing to fill the body out smooth and shot it with automotive base/clear. When you step on the brakes, makes it look like the rocket is taking off. Doug
Postby Vedette » Tue Jan 22, 2013 3:24 pm
doug hodder wrote:Those are '59 Caddie taillights. I turned a rocket shaped body on the lathe, and routed 2 grooves into it and slipped in fins. Ran it through the band saw to give me 1 flat side for mounting. Coated it all out with epoxy and thickened epoxy fairing to fill the body out smooth and shot it with automotive base/clear. When you step on the brakes, makes it look like the rocket is taking off. Doug
Thanks Doug
Wonderful job!
I have a set of 59 Caddy tail lights here with no home.
Loved what you did.....perfect application for your Rocketear Trailer.
Thanks again.
Good Roads
Brian
Good Roads
Brian & Sandi
Vedette
Images: 443
Postby Mary C » Tue Jan 22, 2013 9:59 pm
Doug that is one fantastic rocket tail light !!! WOW !!! :applause: :applause: :applause:
and here's to ya :wine:
Mary C
Mary C
Images: 473
Postby GerryS » Wed Jan 30, 2013 8:08 pm
Today, I built up my fat reserves. Tomorrow I build a frame for my solar panel.
GerryS
Postby droid_ca » Thu Jan 31, 2013 10:38 pm
Did you try PrincessAuto??? :thumbsup: :thumbsup:
“Fide Canem”
droid_ca
Images: 176
Postby Vedette » Thu Jan 31, 2013 10:40 pm
Today I got back at Miss Piggy for a few minutes.
Went to Home depot and got some plumbing stuff to build my swamp cooler.
Thought we were just discussing something else......but everthing disapperared??? :thinking:
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
Vedette
Images: 443
