razorback wrote:If you have electricity I believe this is the safest and best way to heat a teardrop.
It comes in two sizes: 24" X 24" and 18" X24"
I have the 18" X 24" unit which is 240 watts. It is installed on the wall between the cabin and the galley next to my wife's feet. It is 1/4 inch thick and is 1/2 inch off the wall and 3 inches off the floor. It does not get hot enough to combust anything. I have an outlet on this wall and I plug in a thermostat and then plug the unit into the thermostat.
You set the temp for what you want and it maintains it.
My td has 3/4 inch foam board in the walls, 1 1/4 inch foam board in the ceiling and 3 inches of foam board in the floor.
We have only camped in temps down to 20 degrees, but the unit maintains the temp at whatever temp you set.
It is a very soft indirect heat that does not lower the humidity of the air.
It works great for us as we never camp without electricity.
Larry
http://www.royaltystudio.com/products/E ... 20J98.html
this is the link to a thermostat similar to the one we use with this heater.
http://www.newegg.com/Product/Product.a ... PAodHm0AvQ
slowcowboy wrote:i got a old furnace out of a pop up camp trailer its a surbuban and a little on the large side.
I got a new thermocuple in it so still trying to get the pilot lite to stay lit. have not done much with it in 3 years.
I am hoping to get the pilot lite to stay lit and then install it into my new wild goose.
slow
Larry
Off Grid Rving wrote: my first choice though. would be a Newport Dickenson Solid Fuel Heater.
of the teardrop which would aid in creating passive cooling during the hot months. It is very effective. Next, I have gotten an Camco Olympic Wave 3 Catalytic propane heater mounted it on the door of the teardrop above the floor vent and slave it off the propane tank. Since your teardrop is also a larger one this would also work for you. The added benefit of this type of setup is the floor venting technique eliminates any condensation in the tear and the heater requires no electricity or battery drain.floor
Guy wrote:Dear Clint,
That is exactly why I mounted it on the door and raised it above the floor. I took seriously your post about not camping where there is electricity which is why I suggested a no electric solution. The panels you linked to require 15 amps per hour of running time. That will drain your battery bank in short time.
