Rubber Hatch Seal Strip, unusual, available?
Postby webbaldo » Mon Jan 28, 2013 10:06 am
Hi there, im about to do the edge moulding on my hatch lid and want to continue using normal cope moulding for the edges.
Im using this type
I dont want to go down the rubber strip type to hide the pop rivets as I dont fancy having the rubber showing on the outside.
Ill be using 3mm alu bar on the inside. Therefore can you get a rubber seal that will hide the ugly side of the pop rivets?
Crude diagram attached!
Above im trying to show a rubber seal idea, the trough in the middle would hide the pop rivet heads?
Any help or better suggestions would be great!
Likes to think he's Norm from New Yankee Workshop
In reality, hes a average DIY'er with a 18x16ft Wooden shed
webbaldo
Re: Rubber Hatch Seal Strip, unusual, available?
Postby CarlLaFong » Mon Jan 28, 2013 12:30 pm
You could use ordinary rectangular section rubber and drill a little hole, part way through, where each rivet extends through the bottom of the 3mm bar. You could, also, use self tapping Tek Screws and cut them flush after installation
http://jkcallin.blogspot.com/
CarlLaFong
Images: 5
Postby aggie79 » Mon Jan 28, 2013 2:57 pm
Instead of rivets, you may want to use Chicago screws and nuts (also sometimes called sex bolts or barrel bolts.) These will give you a nearly flush surface.
Postby webbaldo » Mon Jan 28, 2013 3:17 pm
aggie79 wrote:Instead of rivets, you may want to use Chicago screws and nuts (also sometimes called sex bolts or barrel bolts.) These will give you a nearly flush surface.
Didn't even know they existed. You can only get nickel plated ones easily in the uk, would these be weather proof?
webbaldo
Postby Lgboro » Mon Jan 28, 2013 3:33 pm
Check around the marine supply / repair shops they may have stainless or brass.
Lgboro
Images: 53
Postby webbaldo » Tue Jan 29, 2013 7:44 am
After having a look, I think using 'D' rubber stripping with just the hole drilled out will do.
webbaldo
